o-ring, best thing you could do for FI.
					My 2.7i Build
 You are asking these questions in the wrong section try the turbo section if you haven't already!!!
 And are you located down south ATX?
 1986 325es (69k) Garage Queen Buy It Now 10k;1986 325es (track rat) 2.7i How-To & 1.1/1.3Motronic UpGrade
 1991 318is (daily driver) 1991 318is M42 Maintenance How-To;1989 325i (parts car)Comment
 Ok, well the machine shop is going to o-ring the block.
 Yes, I am located in South Austin.
 '88 325is
 VP UT of Austin Autoholics
 BMWCCA 380364Comment
 Sweet we will have to run-em even tho your turbo will spank me!
 If you need any parts let me know I have two parts cars.
 Here's the new block. Honed, o-ringed, cleaned and rebuilt with new bearings and 2.7L internals out of an S-ETA.
 The head has been decked and will have a new camshaft and rocker arms installed. Hopefully get it back together this week.
 '88 325is
 looks great!
 I hope to be rebuilding a spare engine this winter.
 please make a list of all the parts and expenses to do your rebuild
 I'm extremely interested in it!
 thanks man,
 Awesome build
 mtech1/2jzgte/r154/275tire
 function>formComment
 666 fab adapter, Holset H1C turbo, TCD fuel setup, FMIC, 10lbs of boost. I'm going to post a huge writeup on e30tech whenever I finish.
 Anyway, this came in today:
 It's just a stock camshaft, totally fine for my power ambitions. $189 shipped from azautohaus.com.
 '88 325is
 Hope you spray it before you install it. Lookin good!!!
 1989 cirrisblau-metallic 325iComment
  Your answer does not make sense but I will assume it was a typo and you wanted to put this noobie in his place;) Your answer does not make sense but I will assume it was a typo and you wanted to put this noobie in his place;)
 I am sorry that you choose to spread mis information...I have just finished a full bottom end build having to choose between a 91 325is block and an 86 eta block..The eta block had superior oiling in the main bearing area...The bearing itself had larger locks on the ETA and a full radial oiling groove as opposed to the 325is bearing that was very different.....This is a fact, so I will say it again,THE TWO BLOCKS ARE NOT THE SAME.....so it seems you are still incorrect
 If my credability is not good enough for you please take time to call Teddy or Jim at Metric Mechanic that have been building these engines for 20 years and I am sure you will get the same answer I am giving you....
 2.7L M20 11:1 COMP 195 whp Dyno Dynamics 2380lbsComment
