My 2.7i Build
  • Jordan325iC
    • Aug 2005
    • 1697
    #46
    Originally posted by nando
    if it's already got it, you don't have to worry too much.
    you can pre-prime the oil pump pretty easily on an M20. There's a little round aluminum plug with a BMW logo on it near the intermediate shaft. If you remove this you will find a shaft, a couple plastic washers, and a gear - remove them, and using a long hex extension (they make them specifically for priming oil pumps, but you can probably rig something up), turn the oil pump with a heavy duty drill (clockwise) to build pressure & fill the oil filter. You can turn on the ignition (but don't start) and wait for the oil light to go out. after that, put it back together and start it up. :)
    hope that makes sense!
    Haha, kinda. I'm actually building the engine completely out of the car and then dropping it in as one piece, so I don't know if I'll be going that route. My engine builder just suggested cranking the car with no spark before I start it, so I'll probably go that route.
    '88 325is
    VP UT of Austin Autoholics
    BMWCCA 380364
      • 34839
      #47
      you're better off priming the pump, then you never have moving parts with no oil on them.
      if you already have it out of the car, it should be even easier to prime it since you can more easily get that cover off.
      • kenika65
        • Aug 2007
        • 1336
        #48
        When are you planning on actually putting it in?
        I have an oil pump shaft so Ill drop buy and prime the motor before you drop it in.
        Also I am moving in to austin on the 1st!
        1986 325es (69k) Garage Queen Buy It Now 10k;1986 325es (track rat) 2.7i How-To & 1.1/1.3Motronic UpGrade
        1991 318is (daily driver) 1991 318is M42 Maintenance How-To;1989 325i (parts car)
        • Jordan325iC
          • Aug 2005
          • 1697
          #49
          Got the head back.
          Had the thing resurfaced and installed a new camshaft and rocker arms. $120 for the resurface and head assembly, $189 for the camshaft (azautohaus.com) and $160 for the rocker arms
          Head installed:
          Spring loaded tube-o-death w/ new o-rings installed via tiny zip ties. Gives the intake plenty of room to slide on.
          Painted my intake manifold, turned out pretty good:
          John Volk 666 fab adapter w/ Holset H1C 16cm turbo, "tial" wastegate.
          Found individual gaskets for the manifold so I won't have those enormous spark plug protectors looking ghetto and hitting the turbo anymore. I think they were $3 a piece from azautohaus.com.
          The oil cooler setup:
          How it sits now:
          I dropped the flywheel off at the machine shop today, so once I get that back in a day or two I'll bolt the tranny up and drop the engine in. Hopefully by Thursday.
          '88 325is
          BMWCCA 380364
          • SpecM
            • Oct 2005
            • 4531
            #50
            looks great! I love the orange block!
            1989 cirrisblau-metallic 325i
            • Jordan325iC
              • Aug 2005
              • 1697
              #51
              It's red damnit! :)
              '88 325is
              BMWCCA 380364
              • SpecM
                • Oct 2005
                • 4531
                #52
                Originally posted by Jordan325iC
                It's red damnit! :)
                ok ok its red
                my bad
                • TopOfTheLine89
                  • Jun 2007
                  • 919
                  #53
                  Looks great, gonna be mega squirted?
                  97 tacoma 5 spd 4 cylinder
                  2001 330ci 5 speed
                  83 733i 5 speed, (FS)
                  • Jordan325iC
                    • Aug 2005
                    • 1697
                    #54
                    Not for a while. I'm taking baby steps here.
                    '88 325is
                    BMWCCA 380364
                    • Jordan325iC
                      • Aug 2005
                      • 1697
                      #55
                      Well, got her in finally:
                      She's cranking over, but not catching. I can smell fuel, but I really haven't done any troubleshooting yet. However, I did come across one connection that I can't figure out:
                      I meticulously labled everything I disconnected, except somehow this little guy escaped. I have no idea where that goes to. Just for reference that is the oil dipstick tube at the top of the picture, and you're looking at the driver's side of the block. It comes out of the main wiring harness near the thermostat. It's not AFM, TPS or ICV. Any ideas?
                      '88 325is
                      BMWCCA 380364
                      • E30Idea
                        • Mar 2007
                        • 2196
                        #56
                        Looking good.
                        If your not running MS than what are you doing for an EMS?
                        ** Lot's of M20 turbo parts for sale.**
                        Turn key track car.
                        http://www.r3vlimited.com/board/showthread.php?t=222066
                        • SpecM
                          • Oct 2005
                          • 4531
                          #57
                          maybe its the EVAP purve valve harness?
                          does it reach to just underneth the TB?
                          • Jordan325iC
                            • Aug 2005
                            • 1697
                            #58
                            Ah, good idea. But it's not that.
                            '88 325is
                            BMWCCA 380364
                            • SpecM
                              • Oct 2005
                              • 4531
                              #59
                              OK... CPS or oil level?
                              I'm just shooting from the hip
                              • Jordan325iC
                                • Aug 2005
                                • 1697
                                #60
                                OIL LEVEL, that's right! The oil level sensor connector is fubar and I'm waiting for another one to come in. Thanks for making me remember.
                                Unfortunately that isn't the magic bullet for why the car won't run. I'll do some more troubleshooting on Wed.
                                '88 325is
                                BMWCCA 380364
