Late model pump with early system?
  • billythekid
    • Nov 2019
    • 24
    So i started a rather big job for myself by changing my water pump and timing equipment and i didnt pay attention when ordering the pump. I have a late model pump and an early model system. I was wondering if anyone had used metal pipe and couplers to replicate the T in the pump or if anyone has welder a second opening for the t onto the pump. Might be important to note that its an 87 325is
  • e30davie
    • Apr 2016
    • 1788
    I would just get the right pump.
    • billythekid
      • Nov 2019
      • 24
      A little late for thay
      • reelizmpro
        • 9558
        Do you have the late model pump with the carrier? if so, it doesn't have a nipple for the return on it as the later models had it on the tank and I don't know if the late model pump can be retrofitted to the early style carrier but that's what you would need to do. I am currently running a TRE/Walbro on my M3 and 323i, both of which had a dual pump setup stock. I just by passed the main pump under the car and retrofitted a high flow pump in the early style carrier.
        88 M3 - LACHSSILBER
        89 M3 - ALPINEWEISS II
        • digger
          • Nov 2005
          • 6209
          I think he means water pump. As said just buy the correct one. they aren't expensive and return the other or resell it
          • billythekid
            • Nov 2019
            • 24
            It looks like it would be very simple to just put a t in the hose leading to it. It would replicate what the nipple on the pump does. Only thing different would be how far down the line it is
