Help me pin out a 173 DME?
  • 325e '87
    • May 2017
    • 503
    Hello, my son has a 173 DME for his 2.7i motor that he is putting together. Can somebody point me to a diagram so I can check all the pins and confirm that it will mate to the wire harness he’s got?
    My son has the 1987 325e, 2 door, 5speed
    I daily the 1989 325i, 4 door, 5speed
  • McGyver
    • 4636
    That page has all of the Electrical Troubleshooting Manuals, just find your year and read it. Section 1360 should have all of the ECU pins, functions, wire color, and wire size.
    • 95BMWIC
      • Apr 2012
      • 353
      More info to help
      BMW E30 ECU pinout and electrical tests: where the ECU lives, how to access it, and pin-by-pin diagnostic checks.
      • 325e '87
        • May 2017
        • 503
        Thanks you for the guidance.
        • jeffnhiscars
          • Jun 2011
          • 6011
          I did a 173 motronic upgrade in an 87 eta using an 87 harness and did not have to change anything on the harness. Externals like injectors, reference, crank and oil level sensors had to be changed but zero on the harness
          Alice the Time Capsule
          • 325e '87
            • May 2017
            • 503
            Good to know, thank you.
              • 34844
              What? Are you sure about that? Motronic 1.0 used on the 84-87 eta has a completely different connector, with like 20 less pins. The entire harness is completely different. I know you're a long-time member, but there's no way this is true unless you had an '88 seta.
              • efficient
                • Feb 2012
                • 3312
                i did the same. i grabbed a 87 325is harness and plugged it straight into my 86 325e harness and everything works other than changing afm, cps, dme 173,
                  • 34844
                  Oh, I think I misread. He swapped an 87 325i harness into an ETA. I thought he was saying he plugged in a 173 DME into the eta harness. Yes, that makes sense. :)
                  • jeffnhiscars
                    • Jun 2011
                    • 6011
                    Nando...remove mask, take deep breath, replace mask :)
