Timing Belt inspection?
  • Westija
    • Aug 2015
    • 90
    I purchased a 1989 325i a few months ago and the PO mentioned he had the T Belt done but did not have any documentation. Is it possible to determine if it has been replaced recently by visually inspecting it?
    Do I need to remove the Upper Cover or can I see by removing the distributor only?
  • varg
    Florida Turbo Man
    • May 2014
    • 3439
    The whole top cover has to be removed to see it well but you can't really tell much from a visual inspection anyway unless the belt is worn, damaged or excessively old. If you have no idea when it was replaced, no sticker with a mileage and date, etc. you're better off just replacing it. Head rebuilds/replacements are $$$
    IG @turbovarg
    '91 318is, M20 turbo
    • tomstin
      • Mar 2015
      • 570
      When in doubt, replace it!
      2004 525i Manual - 1985 325E Coupe Manual
