M30 swap for my Olive Drab Vert!
  • RagtopE30
    • Dec 2010
    • 1869
    #91
    So I have another dilemma. The block is supposedly from an E34 and is a M30B35. The problem is that the oil pump chain tensioner I bought for the B35 is not usable with this block because the boss for the mounting pin is non existent! So I have to use the old oil pump shims. But from what I can see on realoem all the e34s had the chain tensioners. WTF!
    Edit: After looking over the block and the lack of certain engine mount mounting points I have concluded that this is a B34 block that has been punched out to a 94.0056 bore. Not a big deal except I had GoodNTight make me custom mounts for a B35 and they will not work with this block. And I still have to find shims for the oil pump.
    Oh and new pictures on post #90!!!!!!!
    450whp 524 lb-ft 1988 336ic In progress
    http://www.r3vlimited.com/board/showthread.php?t=250709
    • Good & Tight
      • Apr 2004
      • 2057
      #92
      It's actually a good thing that it's a B34 block, they are stronger than the B35.
      The B35 blocks are prone to cracking around the cylinder headbolts.
      Search for "Qbang" he makes a real nice set of B34 mounts. I will buy your B35 mounts back.
      Need a Turbo manifold? We have them in stock- Click here---> http://rapidspoolindustries.com/
      ____________________________
      E-mail Panayiotisx2@gmail.com
      Dyno vid http://www.youtube.com/watch?v=C7aM7..._order&list=UL
      • RagtopE30
        • Dec 2010
        • 1869
        #93
        Otis, you are the man. Thanks for your help throughout this build!
        • RagtopE30
          • Dec 2010
          • 1869
          #94
          The baby is home!!!!! I have to wait for the new oil pump sprocket, chain, and shims to get here before I knock out the timing chain and oil pan but IT IS HOME!!!
          • dougie30
            • Apr 2012
            • 1708
            #95
            So excited to hear this thing scream! I would love to do this but i can only dream..
            Sent from my SPH-L710 using Tapatalk 4
            M30 is God's motor.....but Jesus drives an M60'd car -slammin.e28
            • RagtopE30
              • Dec 2010
              • 1869
              #96
              Thanks for the support man! As usual life is keeping this build on the very slow but steady track. I should have the oil pan with oil return bung welded in and the intake with the TB mount flipped back this weekend.
              I recently moved into a small shop and I am proud to say that I have removed the radiator support and am working on making it a bolt in affair!
              I will add pictures of the gapping hole in the front end tomorrow.
              • RagtopE30
                • Dec 2010
                • 1869
                #97
                Got the radiator support completely divorced from the chassis. I spent a few hours afterwards removing unneeded brackets and cleaned up all the old welds and tabs.
                While I was in there I also installed my Non ABS master cylinder and lines! Finally! I have had these parts for a couple of years now.
                • Doughnut
                  • Oct 2007
                  • 869
                  #98
                  Mate, looking good!
                  Keep up the good work, every post you make makes me miss my e30m30 monster more and more....
                  They are a whole bunch of fun!
                  ///Monstrosity. (OO≡≡[][]≡≡OO)
                  Aside from showing yourself to be offensive, lacking experience and ignorant in the ways of business, you're also illiterate and imprudent. Beyond that, your sense of liability is severely impaired.
                  • jeffnhiscars
                    • Jun 2011
                    • 6011
                    #99
                    Loving the shop Matt.
                    Alice the Time Capsule
                    • RagtopE30
                      • Dec 2010
                      • 1869
                      #100
                      Damn it! Why do I get side tracked so easily?
                      Today's distraction, I acquired some unobtainium that may find it's way onto the vert!
                      I present a set of 1983 Japan Epsilon 15x7" 4x100 e21 fitment mesh wheels
                      • jim325
                        • 228
                        #101
                        Got my wastgate on, when I get it set right, 16 psi, right now 18 psi cuz hitting overboost. LOOK OUT, IM COMIN FOR U!!! (When urs gets done after ur 9million side projects)
                        89 325i: 86 535i motor+trans, JE forged pistons, MLS head gasket, ARP head studs, Comp turbo, GoodNTight b34 turbo manifold, e30.de motor mounts, AKG 75D engine/trans mounts, custom 3" exhaust, intercooler, MS2PNP, Megan Racing Coilovers.
                        • rav320uk
                          • Jun 2004
                          • 1337
                          #102
                          Sub'd!!:d
                          If you have bought items from me, please leave feedback below.
                          If you are a BUYER, Check My Feedback.:up:
                          http://www.r3vlimited.com/board/showthread.php?t=183860
                          Check out my Euro Build Thread
                          http://www.r3vlimited.com/board/showthread.php?t=215557
                          • RagtopE30
                            • Dec 2010
                            • 1869
                            #103
                            Side projects, homework, and poverty keep this build on a slow and steady track
                            • kylelauffer
                              • Dec 2009
                              • 624
                              #104
                              what power are you shooting for? my spec clutch stage 4 started slipping at the end of summer.
                              • RagtopE30
                                • Dec 2010
                                • 1869
                                #105
                                Goals for reliability and daily driving are 425-450hp to the wheels. This is of course with the mega squirt and moderate boost.
