Another E30 M30 Swap Thread, this time with an 84 318i
  • G-Man the Visionary
    • Apr 2013
    • 543
    #136
    How did homeboi's car turn out?
    Streetable poly mounts, trans mounts are here!
    http://www.r3vlimited.com/board/show...ght=streetable
    '94 318i
    '07 335i
    '11 X5
    '89 325ic m30b35
    • Etfren
      • Feb 2014
      • 93
      #137
      Pretty good. Got the motor and trans re-installed and most of the wiring hooked up. Need a few little things before its ready to fire up, but I am hoping to have my car running by the weekend.
      I'll post pics of my car when its running and all back together. Although I am starting to like the look of it with no hood and grille. :)
        • Apr 2013
        • 543
        #138
        Did you guys find the "local" tb and other parts?
        '94 318i
        '07 335i
        '11 X5
        '89 325ic m30b35
        • the imitator
          • May 2013
          • 1006
          #139
          not quite unfortunately, haven't put forth the greatest of effort in regards but hey, got most of it done! wiring is semi plugged in, and the driveline is in too.
          I got me finger stuck between a trailing arm and rear subframe while tossing it, cussed in front of a father of three thinking my finger nail was gone and simply nothing had happened.. left finger nail tracings on the subframe though! hehe
          fun times
          • Mr. Burns
            • Aug 2011
            • 3516
            #140
            I like your style
            Originally posted by flyboyx
            i have watched my dog lick himself off a few times
            • the imitator
              • May 2013
              • 1006
              #141
              lol!
              • the imitator
                • May 2013
                • 1006
                #142
                So here is the c101 for an 1984 318i L-jet m10, it slightly differs from what is shown in franks swap guide, so here it is:
                • glnr13
                  • 1334
                  #143
                  here's what I did on my 84 m10 to 90 m30 harness (735i).
                  m10 --- m30
                  pin 1 -- pin 1 blue
                  pin 2 -- pin 2 i didn't write down the color
                  pin 4 -- pin 4 brown/yellow
                  pin 6 -- pin 6 green/yellow
                  pin 7 -- pin 13 green/violet
                  pin 8 -- pin 18 black/yellow
                  pin 10 -- pin 7 green
                  pin 16 -- pin 5 brown/green
                  pin 17 -- pin 11 white/green
                  edit: no adapter, spliced the m30 connector directly on to my harness.
                  don't forget to do the wires in the glove box to get your cluster working.
                  white -- pin 3 black/white
                  black -- pin 9 black
                  edit: i didn't route these wires to the harness connector, i just did it in the glove box to the ecu.
                  • e30m3s54turbo
                    • Jun 2010
                    • 3290
                    #144
                    m10 --- m30
                    pin 1 -- pin 1 blue
                    Thanks for sharing. I will need this for my 85 euro 320i with a m30 swap.
                    • glnr13
                      • 1334
                      #145
                      no worries. sharing is caring
                      • the imitator
                        • May 2013
                        • 1006
                        #146
                        Right on glnr, thanks for the contribution!
                          • Apr 2013
                          • 543
                          #147
                          bump for updates
                          '94 318i
                          '07 335i
                          '11 X5
                          '89 325ic m30b35
                          • the imitator
                            • May 2013
                            • 1006
                            #148
                            Studying for right now, looks like I'm leaving sooner than expected, but that means starting my career.
                            I plan on bringing this car with me so updates will be on a rampage soon, not that theirs a lot left.
                              • Apr 2013
                              • 543
                              #149
                              you're almost done, just wrap it up already
                              '94 318i
                              '07 335i
                              '11 X5
                              '89 325ic m30b35
                              • the imitator
                                • May 2013
                                • 1006
                                #150
                                Can I just have the engine out of your 335i please..
                                EDIT: found one local with zero oil pressure for $750.. turbos and all
