Another E30 M30 Swap Thread, this time with an 84 318i
    Originally posted by the imitator View Post
    I decided to go with a 3.73 with the g265.. should be interesting, I havent really checked final drive ratio, if anyone can Chime in here that would be awesome!
    Final drive ratio is .81. It will be fine with a 3.73, I ran the same combo for awhile.
    Need a Turbo manifold? We have them in stock- Click here---> http://rapidspoolindustries.com/
    ____________________________
    E-mail Panayiotisx2@gmail.com
    Dyno vid http://www.youtube.com/watch?v=C7aM7..._order&list=UL
      Thank you sir, should be a decently fun car.
      Looking forward in using your turbo manifold in the future, for now it sits shiny on a shelf.
        Put in a brass pivot pin from Ireland engineering today. Yippy.
          It looks like garagistic's motor mounts have space to redrill for position 3.5, yes I am banging my firewall a tad more to fit in the new radiator.
            Pics or it didn't happen!
            Sent from my SAMSUNG-SGH-I337 using Tapatalk
            Si vis pacem, para bellum.
            New Hawtness: 1995 540i/6 Claptrap
            Defunct too: Cirrusblau m30 Project
            Defunct (sold): Alta Vista
            79 Bronco SHTF Build
              well the other mount is self explanatory and there's plenty of room, this is the mount in question, there's plenty of room for redrill here as well, its just locating the new hole correctly.
              In this picture the mount is sideways, unless I am misunderstanding something here; all I have to do is find the angle where my 2 fingers are pointing, and simply drill a new hole using that angle.
              for an example, if I want to move the mounts back one inch, and the angle of that part of the mount is 45 degrees, all I have to do is move my drilling location 45 degrees by 1 inch.
                Heres another example
                  i don't think you can gain an inch out of the mounting plates, you're going to run out of material to put the holes in for the rear bolts. maybe a 1/4" on the plate and 1/2" where the mounts attach.
                  also keep in mind your driver side mount is going to hit the dipstick if you move the mounting holes back so you'll have to notch it.
                  so if you're thinking of sliding it back the new holes should be inline with the original holes. if you go 45° down i think you're going to have the steering rack come into contact with the oil pan. if you go 45° up you're not going to be able to close your hood.
                    That was used for an example, and I'm not drilling on that side of the engine mount, only the motor mount/bushing side of the mounts and I only need 0.57" so I'm fine.
                    The only mount I'm questioning is the passenger side, look at the pics again, see how its installed at an angle off the subframe... That's the angle I need in order to drill the new whole. If you look at my first picture where my fingers are that's where the angle is shown. If I'm correct all I do is take the angle found in that first picture, and use that to locate my new hole.
                    Secondly, I'm not trying to bring my motor forward, or else I would have bought different mounts, my pushing it into the firewall even more.
                    For an example, I need to move it 45 degrees left by 0.57"
                      ah, i completely understand now. i was overthinking it from the plate side.
                      13mm nut + 2-3mm clearance for socket. I agree, there's room there for another 1/2"
                        Coming along nicely bro! I'm impressed!
                        Streetable poly mounts, trans mounts are here!
                        http://www.r3vlimited.com/board/show...ght=streetable
                        '94 318i
                        '07 335i
                        '11 X5
                        '89 325ic m30b35
                          Your points were valid though! lol
                          Thanks mang! just had the brown santa clause in short shorts visit.
                            MOAR!
                            I got my steering rack today, it is indeed the 2.7 LTL and came out of a 2001 z3 convertible with a 2.3 liter engine.
                            A little dirty
                            Simple green, and Bar keepers friend
                            Shiny, and cleaner
                              Gonna run PS?
                              '94 318i
                              '07 335i
                              '11 X5
                              '89 325ic m30b35
                                Gonna run PS?
                                You know it! Being a daily driver, I don't want to muscle around in parking lots.
