Another E30 M30 Swap Thread, this time with an 84 318i
  • LowR3V'in
    • 4209
    #31
    Originally posted by Click
    Hmm its known fact that the 265 gearbox is weaker than the 260/6, keep that in mind when you put that snail on...
    Where did you get this info?
    I thought it was the other way around. Not that it matters really.
    Who blows up trannys?
    • Doughnut
      • Oct 2007
      • 869
      #32
      Originally posted by the imitator
      Here's my take on it, The head on my car doesn't have the correct finish on it, thus ill have major oil seepage. That being said if I am sending my head in to get a proper finish, it will get getting MUCH more than just a deck skimming, and when you play that token, why the hell reuse a headgasket.
      But If I decided to turbo it completely stock as is, Ill do it Knowingly what may happen.
      I think I've missed your point...?
      Regardless of the head being skimmed or not, a used head gasket is not worth it in my opinion.
      ///Monstrosity. (OO≡≡[][]≡≡OO)
      Aside from showing yourself to be offensive, lacking experience and ignorant in the ways of business, you're also illiterate and imprudent. Beyond that, your sense of liability is severely impaired.
      • the imitator
        • May 2013
        • 1006
        #33
        Ya you did, but with my help! haha I made the confusing.
        The moral of the story is, I WOULD use this gasket if my head was skimmed, but It costs money to get a head skimmed, and while I'm there I may as well do valve work, porting ETC, and at that point, you've put so much money into just the head, it would be silly to reuse a headgasket, if you have the money for a rebuild just kill another 200 and get a new gasket.
        But If I was to say screw it, and turbo this motor stock, I may say screw it, Doing headgasket on an m30 is a 2 night job at most, by yourself.
        This is all hypothetical to be honest, chances are, she will stay stock until I find interest in another swap, or I plan to turbo this beast.
        • marshallnoise
          • Sep 2013
          • 3148
          #34
          I think the biggest difference is the detachable bell housing, not strength. I will be running the 240, but no boost.
          Si vis pacem, para bellum.
          New Hawtness: 1995 540i/6 Claptrap
          Defunct too: Cirrusblau m30 Project
          Defunct (sold): Alta Vista
          79 Bronco SHTF Build
          • Click
            • 637
            #35
            I would post some links to my e28 but you don't want them haha. I'm sure the 265 is plenty strong however, as long as you aren't dumping the clutch in first...
            ส็็็็็็็็็็็็็็็็็็็็็็็็็
            I need you to exfoliate my ballsack
            Build Thread?
            • the imitator
              • May 2013
              • 1006
              #36
              The only reason I say that though is because that is where I went for my information regarding this whole g265/6 vs g260/6 thing.
              People say they are the same internals, but why would the g265 box be slightly longer? If the extra 3/4 is there, what is taking up that void? It can't be that the g265 has a 3/4 inch hollow spot in it.. Do parts numbers cross and I haven't done my homework? If it's simply a large bell housing I'll make the assumption that the throw out bearings on g265s would be thicker in order to make up for the depth.
              The problem I hear with g265's are with people who consistently skip 1st gear from a stop and pursue 2nd as their new 1st gear and end up with bearing problems.
              • kronus
                • Apr 2008
                • 13028
                #37
                the one with the 1st-2nd confusion is the 265/5 dogleg box. The 265/6 is a related overdrive box, and both have completely different (beefier) internals to the 260/6.
                cars beep boop
                • the imitator
                  • May 2013
                  • 1006
                  #38
                  Great clarification right there. I would feel comfortable with either tranny and wouldnt hesitate to drop it in 1st with either tranny.
                  I like the g265 for every reason, I'll be using the e30 m3 tranny brace, which makes the g260 brace look like a tin can!
                  here are some totally misc pics:
                  • Jean
                    • 18228
                    #39
                    This brings back memories doing m30b35 swap in my 84 318i . It's damn simple :)
                    Can't wait to see it with turbo!
                    • the imitator
                      • May 2013
                      • 1006
                      #40
                      Might give this 84 ABS though.. not sure if the ireland engineering BBK will like it though.
                      • JoeMadoo
                        • 936
                        #41
                        This will be a fun car, especially with the m102 turbo stuff
                        '86 E30
                        '05 E53 X5
                        '72 Firebird
                        '10 Prius
                        '03 Tundra
                        • the imitator
                          • May 2013
                          • 1006
                          #42
                          This is where I need motivation man... my parts list is great for turbocharging!
                          I have nearly the full turbo kit, I'm missing a return line and the work associated with tapping a return line.
                          I have the megasquirt 2 from diypnp, LC-1 wideband, coilpack, iat sensor; The engine already has arp headstuds.. blah blah.. I'm about 85 percent ready parts wise.
                          but for some reason I feel the "want" to sell the turbo parts.. the other side tells me "wtf are you thinking?"
                          • the imitator
                            • May 2013
                            • 1006
                            #43
                            small update, nothing gnarly, got out in the 20 degree weather and spent a couple hours on getting the wiring lose, I came to the obviously conclusion, if I want ABS I need the entire wiring harness off the parts car.
                            This is the fun part, but It's been a leisure journey, jammin good tunes, and laughing with friends, makes this job seem effortless.. its more time if anything.
                            Just title every wire you unplug/remove.. easy.
                            • the imitator
                              • May 2013
                              • 1006
                              #44
                              Update coming soon. more prep work includes:
                              Getting parts car on lift and start removal of parts.
                              sold turbo kit, bought otis turbo manifold, M5 clutch,TB,etc.
                              • Etfren
                                • Feb 2014
                                • 93
                                #45
                                Hey guys, so I am helping out with this project and stealing some parts off the parts car for my M30 swap too. Did some work on it tonight to prep for taking the motor out.
                                Front suspension and steering rack removed.
                                GC suspension and BBK off the car.
                                Also cleaned up the BBS wheels.
                                This one got curbed and will need some repair.
                                Rear rotors removed and getting the rear subframe ready to pull out.
                                Thats all for tonight. Motor and trans will be out before the weekend, more updates soon!
