Honda K24 swap interest?
  • Motheye99
    • May 2018
    • 853
    #346
    S54>2jz
    91' 318is 90' 325is
    Originally posted by Sonny
    Buy the E30s, they ain't gonna last long
    E30 can make you, E30 can break you
    "He who controls the Nova's, controls the Boomers"
    • cunninglinguist
      • Mar 2004
      • 281
      #347
      Any way to adapt a Getrag 240 to the K24?
      There might be some decent weight savings there, and the G240 can handle the power.
      • Motheye99
        • May 2018
        • 853
        #348
        I've thought about doing this, I believe it will work. Because 240's bolt up to m50's and they have a adapters for m50 ZF transmissions. You would have to figure out clutch and flywheel.
        91' 318is 90' 325is
        • D3’min
          • Oct 2018
          • 28
          #349
          Kmiata adapter plate or gargistic gonna have it covered
          • D3’min
            • Oct 2018
            • 28
            #350
            Hopefully they offer a g240 adapter
            • E30SPDFRK
              • 5713
              #351
              The G240 weighs 65lbs, the ZF 5 speed weighs 82lbs. Its 17lbs saved, but that weight is in the best possible place to be.
              Byron
              Leichtbau
              • lukeADE335i
                • Apr 2013
                • 1389
                #352
                Agreed - that said, if you wanted to run a G240 it wouldn't be hard, it'd just be a bit of research to nut out which clutch / pressure plate and throw out bearing to use. BMWs are like lego with clutches, so you'd just need to look at different models to find the right combination of pressure plate and throwout bearing that gave you the stack height you needed.
                Earlier in this thread it was mentioned that the adaptor for the BMW transmissions caused slave cylinder issues, but that would likely be easily sorted with an e21 throw out bearing (5mm deeper than most other BMWs, but same design) and if that weren't enough, a slight lengthening of the slave cylinder rod if the e21 bearing still didn't quite work.
                Same as we've been doing for years adapting M20 flywheels to M42s, running M50s with e30 transmissions etc.
                My e30: OEM+ with M30B35
                • agile30
                  • 832
                  #353
                  Someone on Instagram currently has one bolted in his vehicle and seems like he is further along. His screen name is byzaw
                  Originally posted by Good & Tight
                  It takes real man to mount a big woman, all you haters are just scared boys.
                  • LJ851
                    • 7919
                    #354
                    He's also a Mod here and has a build thread. And posted two posts above you.
                    Lorin
                    The M30 is God's engine.
                    • agile30
                      • 832
                      #355
                      https://www.r3vlimited.com/board/sho...d.php?t=408645
                      I am a little slow. Sorry.
                      • E30SPDFRK
                        • 5713
                        #356
                        It me
                        Byron
                        Leichtbau
                        • LJ851
                          • 7919
                          #357
                          Originally posted by E30SPDFRK
                          It me
                          Your car is going to be a Ripper !
                          Lorin
                          • D3’min
                            • Oct 2018
                            • 28
                            #358
                            Just throwing out an idea kswap with AWD using Honda CR-V parts
                            • Wanganstyle
                              • 2828
                              #359
                              So you want to put an engine sideways in a e30 to ruin the weight balance.....
                              And make it understeer more?
                              The e30 is god’s chariot because it’s RWD.
                              Awd is understeer; an e30 325xi handles like shit compared to a rwd e30 325i
                              • stonea
                                • 2892
                                #360
                                I would say this is extremely harsh. It handles different for sure, but as someone who bounces back and forth from is 325ix to his 325i they are both extremely fun and enjoyable to drive.
                                My Garage
                                Feedback
                                Instagram: Stone.Hopkins
