A few questions
  • E30SPDFRK
    • 5715
    I found a driveshaft out of a 87 325e four door. The driveshafts should be the same, right?
    Byron
    Leichtbau
    • E30SPDFRK
      • 5715
      Anyone know?
      Byron
      Leichtbau
      • speedhop
        • 1509
        realoem is your friend...and it'll work just fine :)
        www.ryanwhopkins.com
        • E30SPDFRK
          • 5715
          Yeah, I ended up looking there. Thanks for the help, though.
          Byron
          Leichtbau
          • Funkmasta
            • May 2004
            • 7185
            2 and 4 door are the same for driveshafts.
            If you use my mounts, you shouldn't have to modify the shifter carrier, or selector rod.
            Byron, do you have the pinout information for the B35 and your 86 E30?
            Joe Funk -- Portland Oregon
            That Guy.
            03 X5. 3 liter obviously.
            • E30SPDFRK
              • 5715
              All I have is the info from this thread. Good news about the shifter too!
              Byron
              Leichtbau
              • Funkmasta
                • May 2004
                • 7185
                send me a message tomorrow when I am at work and I will get you the ETMs
                That Guy.
                • E30SPDFRK
                  • 5715
                  Sweet, when are you at work?
                  Byron
                  Leichtbau
                  • Funkmasta
                    • May 2004
                    • 7185
                    9-5 ish pacific time
                    That Guy.
                    • E30SPDFRK
                      • 5715
                      Will do.
                      Byron
                      Leichtbau
                      • E30SPDFRK
                        • 5715
                        New question: I want to get the 533i/M5 flywheel and clutch for my car. They are the same kit, right? Where would be the best place to get them, and is there a better choice?
                        Byron
                        Leichtbau
                        • E30SPDFRK
                          • 5715
                          Anyone know?
                          Byron
                          Leichtbau
                          • speedhop
                            • 1509
                            I wasn't aware that the 533 and m5 had the same flywheel. What transmission? I believe that the m5 flywheel can be run with any clutch specific to trans and 3.5L.
                            RmEuropean.com
                            Art is a good guy and will have it to you in like 3 days.
                            • Funkmasta
                              • May 2004
                              • 7185
                              Byron, the 533 and M5 (and 633, M6, M635) all shared a flywheel. That being said, AFAIK, all big 6 clutches will fit all big 6 flywheels.
                              The E34 M5 clutch is without doubt, the "big daddy" of the bunch, but any clutch for a big six will take whatever abuse you can throw at it. Remember the E30 is quite a bit lighter.
                              I have a used E34 M5 clutch that just came in, but I have yet to actually see it. I generally don't sell used clutches, but this would be so overkill in an E30, that even used it will probably outlast the life of the car.
                              That Guy.
                              • E30SPDFRK
                                • 5715
                                Sounds like I am getting a normal m30 clutch then. Would it just be best to use a 533i clutch and flywheel package?
                                Byron
                                Leichtbau
