A few questions
  • E30SPDFRK
    • 5711
    #91
    Ok, finishing up questions.
    First, where does this go?
    Second, how does this hose fit? It hits both the belt and the little stud on the timing case cover. Hose is for a e32.
    Byron
    Leichtbau
    • e30_kid89
      • Apr 2006
      • 489
      #92
      The first pic the bigger hose goes to your charcoal canister and the other thin end goes into one of the nipples under the middle of the intake manifold.
      Me thinks you're missing a bolt in your lower timing case....
      • E30SPDFRK
        • 5711
        #93
        Yeah I am, but that's not preventing the hose from fitting.
        Byron
        Leichtbau
        • speedhop
          • 1509
          #94
          I chose to shave that bolt right off. No rubbing = no bolt.
          And he is right about the canister...you don't need the purge valve if you choose so, but it's a good way to reduce hose size.
          www.ryanwhopkins.com
          • E30SPDFRK
            • 5711
            #95
            I cant engage reverse without forcing the center console over. I have new engine and transmission mounts and an unmodified e28 shift console.
            How have you guys solved this?
            Byron
            Leichtbau
            • Funkmasta
              • May 2004
              • 7185
              #96
              shifter in backwards?
              -Joe
              Joe Funk -- Portland Oregon
              That Guy.
              03 X5. 3 liter obviously.
              • E30SPDFRK
                • 5711
                #97
                Never took it out. The bushings are pretty worn, but not that bad.
                Byron
                Leichtbau
                • speedhop
                  • 1509
                  #98
                  It's not the bushings. The shift rod coupler/joint...the part that attaches to the gear selector to the rod is no good. Replace that with a new one and see if that works out better.
                  • E30SPDFRK
                    • 5711
                    #99
                    #13 or #2?
                    Byron
                    Leichtbau
                    • speedhop
                      • 1509
                      #100
                      I'd replace both. I wouldn't want to go under the car to tear apart the shift linkage again...pain in the butt.
