Intake looks good, are you going to polish the raised fins and the "3.5"?
M30 5spd
I think so, I'll paint the valve cover first and then sand both.Mtech1 v8 build thread - https://www.r3vlimited.com/board/sho...d.php?t=413205
OEM v8 manual chip or dme - https://www.r3vlimited.com/board/sho....php?p=4938827Comment
Well, no rings yet. I did get the mounts finally. Tomorrow will do some work on the bottom end and will get some pics of the progress. Going to stop by a machine shop and see what they say about the 533 flywheel, I think it's a good idea to get it re-surfaced since the clutch will be new, but I would like a second opinion.
Crank will come off to install these
More progress made today:
taking crank / bearings out
main caps actually have numbers on them 1-7, so can't screw these up
cleaning the block
painted
Next weekend plan is to put it all back together. Getting closer nowMtech1 v8 build thread - https://www.r3vlimited.com/board/sho...d.php?t=413205
very nice man. thanks so much for taking the time to detail your progress and share your ideas. plus all of the pictures have been great. best of luck with getting it in and running, I'm sure your attention to detail and thoroughness will pay off greatly.
by the way, who's mounts are those?
looking foward to more updates and writeup type of Q&A...Comment
thanks man, I can't wait to get this thing finished though. I am just down to clutch kit/guibo/engine/tranny mounts.
those are mounts from Joe, probably 5lbs each!Last edited by Jean; 06-12-2009, 06:07 PM.Mtech1 v8 build thread - https://www.r3vlimited.com/board/sho...d.php?t=413205
Yay!
Bottom end is almost done, re-honed, new rings, new main and rod bearings installed.
main bearings / crank in.
pistons/rods installed
Painted the mounts and picked up a 91 g260/6 :)
Anyone want a clean b35 head? I got a spare.
Almost done with the engine, had a little fuck up moment with the tentioner and had to remove the timing cover to fix it so I got another gasket to order now.
DOH, oil pan gasket got messed up in the process...
as it sits now, need to slap oil pan and do accessories and wiring.
Lookin good, I spy a flathead V8 in the back.Need a Turbo manifold? We have them in stock- Click here---> http://rapidspoolindustries.com/
____________________________
E-mail Panayiotisx2@gmail.com
Dyno vid http://www.youtube.com/watch?v=C7aM7..._order&list=ULComment
Why of course Mr. Spyderminn, but only if it's a turbo convertible!Mtech1 v8 build thread - https://www.r3vlimited.com/board/sho...d.php?t=413205
