M30 5spd
  • yert315
    • 2734
    #181
    It mounts with the timing cover bolts. You'll have to remove the crank wheel to access the lower one
    • Jean
      • 18228
      #182
      Correct. Fixed that :)
      Placed what I think the last couple of orders for the missing parts.
      e28 535i sachs clutch kit.
      m30 belts/m20 tranny & engine mounts
      large guibo, shifter components
      Need to pick up correct size/length guibo/driveshaft bolts and two starter bolts.
      Now I think all I'll need is the muffler/exhaust tubing...
      • chadthestampede
        • Jul 2008
        • 3601
        #183
        what exhaust are you going to run?
        Originally posted by LJ851
        Feedback
        • Jean
          • 18228
          #184
          Something simple I hope and on a budget. Straight pipes? j/k
          I don't have a cat yet, so maybe 2 into 1 m20 cat - 2.25-2.5" tubing?
          Suggestions?
          • chadthestampede
            • Jul 2008
            • 3601
            #185
            I was just curious.
            I have e28 downpipes or something into a custom welded box for the o2 sensor (which I don't use) which connects to an m20 cat and stock cat back exhaust. It's not particularly pretty but I needed something that worked until I could get an upgrade. I'm thinking magnaflow muffller and maybe cat too, or perhaps just a resonator, who knows.
            It's relatively quiet the way I have it. Btw it cost me all of $5 to do it since I got the down pipes for free and just kind of hacked them up and stuck it all together.
            I say just use red bull cans all the way back.
            Feedback
            • Jean
              • 18228
              #186
              All I have right now are the stock e34 b35 manifolds down to where the cat was cut off. I have some stock exhaust parts from an 89 325i, but I'll need to buy a muffler and a cat. I am thinking a 2 into 1 right after the b35 manifolds before the cat?
              I need to find pictures of a stock e32/e34 m30b35 cat and see if it's 2 in 2 out or if it's 2 in 1 out.....
              • chadthestampede
                • Jul 2008
                • 3601
                #187
                Do the b35 pipes fit? I seem to remember reading that they direct the exhaust right into the side of the engine bay in an e30, but I may be wrong.
                I would ask on mye28 about the cat.
                I actually ran mine on open headers for a bit when I was still trying to work out the kinks, not driving it on the street of course. It sounds awesome though.
                Feedback
                • Jean
                  • 18228
                  #188
                  Yeah, the b35 pipes should clear the front subframe but I have a 318i, so the current exhaust on it is useless. I just kept some exhaust parts from my 325i and maybe they'll come in handy.
                  • yert315
                    • 2734
                    #189
                    If all m30 powered cars have similar exhaust, then the cat is dual-in dual-out. This is how the e32 that is sitting in my garage is set up and it is the stock system.
                    • Jean
                      • 18228
                      #190
                      Shit... then that's probably what I would have to do for BAR.
                      • Jean
                        • 18228
                        #191
                        So I thought this would be the last order of parts, but after installing these and going over the engine I got a couple more things to order and figure out.
                        Clutch kit, large guibo, rotor, belts, mounts and shifter components arrive.
                        e28 535i Clutch kit
                        Test fitting to the 533 flywheel, realized that I need the mounting bolts...
                        I am not sure if I need different flywheel bolts, these appear to be way too long ?
                        Cleaned up the shifter carrier and installed new bushings...
                        Realized I need the mounting hardware for the carrier to the tranny...
                        Now where I have a couple more questions....
                        There is only one small connector on the bottom of my intake manifold for the vacuum line. I marked it as "A" and the bigger one "B".
                        Does "A" go to the FPR or does it go to the elbow for the throttle body?
                        If A goes to FRP, then where would "C" go to?
                        B - I believe goes to the valve for the charcoil canister, correct me if I am wrong on this.
                        C - I thought went to the bottom of the intake manifold, using the thin vacuum line.
                        D - goes to ICV
                        This valve connects to I believe point "B" and the other end goes to the canister yes?
                        How the engine sits now, tomorrow I'll install the fuel rail/lines and injectors.
                        • yert315
                          • 2734
                          #192
                          "A" - goes to the FPR.
                          "B" - you are correct.
                          "C" - there should be another nipple under the manifold for it to connect to.
                          • Jean
                            • 18228
                            #193
                            Does not have another nipple - http://www.briangt.com/gallery/album149/IMG_5814?full=1
                            • yert315
                              • 2734
                              #194
                              looks like you may have the wrong vent tube from the valve cover then. Im not sure what that little hose does other than create annoying vacuum leaks. Based on this realoem picture #13 does not have a "t" for the hose.
                              • Jean
                                • 18228
                                #195
                                That is true, not shown in the picture... and the part I got is slightly different.
                                Check it out, plug in that part number and it shows up / comes up as the one I got :
                                Find URO Parts Crankcase Breather Hose; Air Boot to Valve Cover; 6 Inch with Small Side Nipple 11151276485 at discount prices in our extensive BMW auto parts catalog. AutohausAZ offers a large selection of URO Parts parts online. 1 per car. Fits BMW 535i, 635CSi, 733i, 633CSi, 533i, 735i, 535is, 735iL, L6, L7. 11151276485E 11151720523 14706009589 14706009738 URO-000445 W0133-1640213
                                Same on pelican
                                http://www.pelicanparts.com/cgi-bin/...FILTER_BMWM=ON
                                and http://www.rmeuropean.com/Part-Numbe..._673122FF.aspx
