Whining from the rear
  • ube91
    • May 2021
    • 46
    Took my car out on a test drive after solving some irritating ticking noise and heard some whining noise from the rear of the vehicle. Almost sounds like one of those rubber toy chickens after they've been squeezed, but higher pitched. Most noticeable with the windows rolled down, and when the car is in motion at about 20-30 MPH without your foot on the gas.
  • roguetoaster
    Biggus Tippus
    • 7830
    What did you work on last in the rear? Start there, also check all rotating parts for noticeable play.
    • ube91
      • May 2021
      • 46
      Haven't worked on anything in the rear of the car lately. The ticking noise that I had fixed was from the timing chain tensioner. I wish I could record a video but the wind noise from driving with the windows down would mask the sound.
      • 82eye
        • Jan 2009
        • 2108
        does it change in pitch ?
        first thing i'd check is the diff to make sure it has fluid and to rule it out. they are getting harder to find. after that i'd suspect a rear wheel bearing or maybe even a fuel pump. fuel pumps will whine when they start going bad.
        • ube91
          • May 2021
          • 46
          The sound loops pretty consistently, with no changes in pitch.
          • e30davie
            • Apr 2016
            • 1788
            Is your mother in law sitting in the back?
            • 82eye
              • Jan 2009
              • 2108
              suspect a rear wheel bearing.
              edit : the "loop" should change a bit with the speed.
              • 82eye
                • Jan 2009
                • 2108
                lol
                • GarageBound
                  • Feb 2022
                  • 37
                  Just had my dvr side replaced. If the whining continues without the m-in-law in the back AND in neutral, idling in neutral, while coasting > 30 mph, I'd bet on the wheel bearing especially if there is a change in pitch affected due to speed. During a turn will tell you which turn.
                  • digger
                    • Nov 2005
                    • 6198
                    Go around a few corners at speed in neutral
