What coolant is used for the m44?
  • 318istourer
    • Jan 2025
    • 16
    I've resolved a coolant leak that came from a silicone hose that wasn't tight enough round the radiator however it has now gone low, it's blue and I know this engine is an aluminium block so I would like to know what is the right coolant for this engine so i can top it up
    Thanks
  • MrBurgundy
    R3V Degenerate
    • Mar 2012
    • 5607
    G48
    • packratbimmer
      • Dec 2009
      • 1335
      BMW blue
      • TobyB
        • 5297
        Iron block, aluminum head. cast crank. roller rockers. and stuffs.
        t
        • 82eye
          • Jan 2009
          • 2108
          i moved all of ours over to the vw/audi/porsche pink stuff. it's cheaper than the blue, far easier to source, and is compatible. we have vw as well so it makes stocking the garage a lot easier.
          bmw used to be listed on the product, but they didn't want to pay for the labeling and prefer to push the blue.
          • packratbimmer
            • Dec 2009
            • 1335
            The M44 is known for cooling system problems including head gasket issues. I would stick to the BMW Blue for that car just because I have had such amazing luck with the product for so long. I assume it is formulated for the materials used in our cars. If you are starting out with a new head gasket, you might save a $10 dollar bill per gallon on other formulas. You know about the plastic M44 fittings on the left side of the block and the rear side of the head I'm hoping - change them every 5-10 years as they are a ticking time bomb!
            • 318istourer
              • Jan 2025
              • 16
              From a quick search online is that m44 fitting this part by any chance?: (3-00540) Genuine BMW M44 Cylinder Head Coolant Fitting with o-ring (11531743679)
