feel like something is missing...power *UPDATE GET SEAFOAM*
    it does work surprisingly well for a "snake oil" type product - all that white smoke is actually carbon being burned out of the combustion chambers. :D
      I <3 Seafoam. Just used it on my new E30 (which had been a grand total of 25 miles in the last 7 years). Huge difference. Great stuff. It also made a noticeable improvement in the feel of my R56 Cooper S when I did it a year after purchase. :)
        Hell I'm considering doing it with my 06 E90 just to see! haha
          ^^how much, where?
            ~$10 at an auto parts store?
              Originally posted by JoeyBones View Post
              I did a full seafoam treatment.
              Crank Case, through a vacuum line, and in my gas.
              It gained a surprising amount of pep as well as curing a HORRIBLE rattle which I assumed was my timing chain tensioner being bad or a stuck lifter...The engine runs and sounds completely normal now, even on cold start ups.
              I will likely change the oil and go through the process again. I'm extremely happy with this and it has re-ignited my vigor to keep prepping this car!
              you put some in the oil?
              be sure to change your oil after a little while.
              [/url]
              Team USA Wrestling 67KG
                Originally posted by iamcreepingdeath View Post
                wait what? where can I find more information on this? Is this a common thing? I would have seen it, as i spend some time on M42Club sometimes...
                Yes it's pretty common just like the m47 crank swap, but that costs alot more money. If you want less work, get a block from an m44, get high comp pistons and rods and bolt your head on. You'll have a lot more useable power.
                Originally posted by Wh33lhop
                VANOS: sometimes you just need to go full retard.
                  yes I did, and yes, I plan to change the oil very shortly. Giving it a bit more time to do some cleaning. It's only seen like 30? miles since putting it in. I dont daily drive the car
                    Seafoam.:drink: Still an M42.
                    M52B28 OBD1 - G240 - S4.10
                    Stuff for Sale: 24v swap parts
                      agreed, but at least it's not a sluggish, noisy M42...
