m42 | post yours
  • M3Philipp
    • Jul 2011
    • 278
    #76
    Originally posted by peytonracer4
    before and after cleaned and painted my valve cover. took forever to clean.
    That looks impressive.
    So what did you do?
    What did you do on the left side of the valve cover, looks like new...
    • peytonracer4
      • May 2011
      • 524
      #77
      So what did you do?
      i cleaned it with those pads as you suggested. the next day actually. haha
      then once it was clean i lightly sanded it with 400 grit and then cleaned it with acetone. it looked better but still pretty awful. i'll post pics of that soon.
      then i painted it. it looks INCREDIBLE. it costed $4 for the high temp engine paint. it's matte aluminum. the left side just has light on it that's why it looks different. the hood is just blocking the light, the whole thing is the same color.
      • M3Philipp
        • Jul 2011
        • 278
        #78
        Good to see it worked for you too.
        • S13_E30
          • 309
          #79
          Originally posted by Dj Buttchug
          even more stock...
          makes me want to boost mine!
          • Brilliantrot 318is
            • 1073
            #80
            Transaction Feedback: -click here
            [e30: '91 318is coupe|brilliantrot||e36: '98 318ti|fern green|California top|M-Tech]
            [URL="http://www.r3vlimited.com/board/showthread.php?t=300453"]
            • Dj Buttchug
              • Jun 2010
              • 7677
              #81
              ^ beautiful
              Turbo M42 Build Thread :Here
              Ig:ryno_pzk
              I like the tuna here.
              Originally posted by lambo
              • 5m1dy
                • Sep 2012
                • 13
                #82
                Blurry, and stock ;)
                  • 1073
                  #83
                  ^ beautiful
                  Wow. Looking good my friend. I need those itb's! Have you done any internal work or ecu upgrades?
                  • decay
                    • 5637
                    #84
                    Heheh- looks familiar, but yours is much cleaner :)
                    There is something pleasing about one throttle/one coil per cylinder, isn't there?
                    Interested also to hear how you approached tune w/ Motronic. I had to go all the way up to 24lb injectors + slight rail pressure bump before my wideband threw happy numbers @ WOT.
                    past:
                    1989 325is (learner shitbox)
                    1986 325e (turbo dorito)
                    1991 318ic (5-lug ITB)
                    1985 323i baur
                    current:
                      • 1073
                      #85
                      How is you mpg? Do you daily or weekends only your m42?
                      • 5m1dy
                        • Sep 2012
                        • 13
                        #86
                        Mmmmmmmmmhhhmmm :)
                        Stock Motronic with Ostrich 2.0 running a tune to work with the ITBs and 24lb injectors with an innovate LC1. PO decked my head, so my compression's a little higher than then the tune was for. Am yet to get it properly tuned for myself. The only internal work I've done is to rebuild the whole timing system, which was an amazing improvement. I had so much slack in my sprockets that I swear the cams must have retarded when you blipped the throttle. Next steps are a nice pair of cams, better exhaust set up then a proper dyno tune.
                        • MF DOOM
                          • Apr 2012
                          • 944
                          #87
                          grainy picture
                          • wazzu70
                            • Jan 2005
                            • 1143
                            #88
                            -Nick
                            M42 on VEMS
                            • Vivek
                              attention whore/retard/bitch
                              • 6167
                              #89
                              Originally posted by MF DOOM
                              grainy picture
                              Oh..the things I would do for your engine..
                              1992 Mauritiusblau Vert
                              2011 Alpinweiss 335is coupe
                              2002 540i/6 Black/Black
                              2003 GSX-R 750 (RIP)
                              • roguetoaster
                                Biggus Tippus
                                • 7830
                                #90
                                Originally posted by wazzu70
                                Shiny, so shiny...
                                Seriously, why is the TB not painted?
                                The only things that have visibly changed in two years have been the removal of the cosmoline on the AFM and intake and the addition of two years of dirt/grime.
