Knocking m42 valvetrain
  • Simon S
    • Oct 2004
    • 3758
    Thanks guys. All input is greatly appreciated.
    Yeah – at this point, more run time sounds good. If something gets worse – then it was meant to be. If it gets better – great. I have some Redline ATF that I’ll add.
    Tensioner: at first, I ran the one that was in there (I’m pretty methodical) After it made that noise, I extended a new one and installed it. I can assure you there was loose chain noise for ~3-6 seconds – then it went away. It was a lot louder and scarier than the noise you hear in the video.
    Guides: All new/updated versions. Installed Saturday.
    If it sounds fast, it might be due to multiple dry lifters – which, again, make sense because they would’ve been drained pretty damn well while head was in multiple positions over the week. Also, the fouled #1 & #3 would indicated a more wide-spread issues (all dry lifters) – rather than a possible bent valve.
    and guys – thank you again. I’m gonna rev the fucker – and hopefully not r3v the fucker.
    -----Zen and the Art of e30 Maintenance - / - Zen TOC - / - Zen Summary
    • Dj Buttchug
      • Jun 2010
      • 7688
      ya dude youll be fine. just go drive it for a while. its hard to ignore the terrible sound but i assure you it will go away.
      Turbo M42 Build Thread :Here
      Ig:ryno_pzk
      I like the tuna here.
      Originally posted by lambo
      • Simon S
        • Oct 2004
        • 3758
        Cool. Thanks Chugz.
        (i miss the ChooChoo sig)
        • grantlacey11
          • Jan 2009
          • 680
          Let us know!
          • Danny
            • 14216
            Go romp on it. Same thing happened when I would burn oil due to my shitty CCV system on my m42 turbo.
            • Massimo
              • Jan 2008
              • 3207
              Yeh when I did my hg i soked the VW lifters in oil for about a week. It took a good 10 to 20 min before they stopped making noise. Garentee it is your lifters.
              • NISHO578
                • Sep 2009
                • 17
                You are OK bro!! dont worry it is out of time one teeth all you have to do is move the chain one teeth and then before you start the engine make sure you crank it with a range two turns to make sure you move the chain in the right direction if it is free then start the car and it would be no more diesel sound like it would go back to gas engine. call me if you want (818) 674-0462
                where are you located?
                • Dj Buttchug
                  • Jun 2010
                  • 7688
                  umm your wrong. stfu
                  Ig:ryno_pzk
                  • JT325is
                    • Oct 2009
                    • 1242
                    Originally posted by dj buttchug
                    umm your wrong. Stfu
                    lol
                    • Pantless Spency
                      It's McRib time!!!
                      • Feb 2011
                      • 7283
                      didn't know they now had phone numbers with smiley faces in them, shit i want one.
                      good luck with your m42 troubles.
                      • Brandon12V
                        • 1318
                        your motor wouldn't be idling that well if you had a bent valve. easy way to tell would be a dry leak test just to rule it out completely. I'd have to agree it sounds like noisy lifters.
                        Originally posted by Ryan...
                        It now emits a beautiful blue-ish yellow/green smoke from the exhaust?? No idea what would cause that color, but I assume its good.
                        • M42Power
                          • Dec 2009
                          • 519
                          As said before, hydraulic lifters, just go for a drive. When i changed my HG also had horrible lifter clapper, drove it and went back to smooth
                          Originally posted by kendogg
                          Don't know, but the E90 wasn't designed from the ground-up intending to be a racecar like the E30 was.
                          OG RACECAR
                          • Hick
                            • Sep 2005
                            • 6451
                            if driving it does not work pull the cams and get to the lifters. Youll want to put a 0w oil in there, or something else heavy. Pump some oil in the port on the lifters and reinstall.
                            Originally posted by vlad
                            • Simon S
                              • Oct 2004
                              • 3758
                              Thanks Hick - looks like I'll be trying that tomorrow..
                              After an hour and fifteen of run time (1.5-2.5K rpm) - no change.
                              Idle is rough. Can sticky lifters cause rough idle?
                              • McGyver
                                • 4636
                                dude, i really wish i could help, but i know nothing of m42/4 engines. i am intrigued and hope it all turns out to be something simple, good luck!
