wideband system
  • bmwm42
    • 6300
    wideband system
    going turbo and would like a wideband sensor, which system are you guys running and is it pretty easy to use. Stupid questions i know but help me out will ya?
    Originally posted by bmwm42
    PNW vulture pm me for parts
    Strategic nw e30 command
  • Cronopoulos
    • Jul 2011
    • 2187
    AEM uego or Innovate LC-1 both have never failed me in the past.
    Project log -- DIRTY 30
    2.7i * Megasquirt tuned * E85 powered
    • bmwman91
      • Oct 2004
      • 3134
      LC-1 here. Be sure to install it correctly.
      Transaction Feedback: LINK
      • Dj Buttchug
        • Jun 2010
        • 7678
        LC1 here as well.
        Turbo M42 Build Thread :Here
        Ig:ryno_pzk
        I like the tuna here.
        Originally posted by lambo
        • bmwm42
          • 6300
          thats what i was thinking of going with and fuck seems like a bitch to do it right is there a pnp kit out there that one doesnt have to bend over to buy?
          • Cronopoulos
            • Jul 2011
            • 2187
            Are you on stock motronic?
            • bmwm42
              • 6300
              Yes I eventually will go to megasquirt
              • Cronopoulos
                • Jul 2011
                • 2187
                ^^ Borrowed from the interwebs....
                O2 sensor.
                As stated earlier, i highly recommend th LC-1. Place it in the stock sensor location and hack off the pigtail from your old sensor. If you ever want to go back to motronic, the LC-1 can simulate a narrow band.
                Wire the LC-1 straight in to the pig tail and seal it with heat shrink
                Pin 1- Sensor GND- GRY
                Pin 2- Signal - BLK
                Pin 3- GND- White
                Pin 4- 12v- White
                • bmwm42
                  • 6300
                  thanks much appreciated
                  • ak-
                    • 12422
                    LC-1 here on Motronic.
                    Swaggin'
                    1991 325iS turbo
                    • unevolved
                      • Nov 2011
                      • 714
                      I think I may be in the minority, but LC-1s have failed me in the past. The best I've ever used was by E-Controls, but that one was really more for a laboratory setup.
                      Not saying the Innovate are bad, but they're not perfect. They work fine out of the box, but all the ones I've had problems with were a year or two old and just refused to work right.
                      1991 318i SOLD
                      2003 325i SOLD
                      Racecars and stuff.
                      • Dj Buttchug
                        • Jun 2010
                        • 7678
                        the lc1 requires some tending to every now and then. It needs clean air calibration right out of the box and from time to time during use. Ive heard some stories like the above post as well. I guess it depends what generation you have. I have the newest one with a G5 analog gauge and its great.
                        Ig:ryno_pzk
                        • jaywood
                          • Jul 2010
                          • 4528
                          I used an lc-1 in my old setup and it worked flawlessly for the year I had it
                          I've got an MTX-L waiting to be installed. Will report back
                          • TobyB
                            • 5266
                            Have run an LM-1 for years now. Logging throttle and revs really aids in tuning- you
                            can tell immediately where in the maps the problems are.
                            Or which carb circuit, as the case may be.
                            t
                            • bmwm42
                              • 6300
                              all this is really informative as i have some long term plans with the m42
