Ventilation in valve cover?
  • Dj Buttchug
    • Jun 2010
    • 7688
    Originally posted by wazzu70
    Well mine is routed to atmosphere too because I have not got around to makimg a proper solution yet :) So dont feel bad.
    I plan to route from the VC to an oil seperator/catch can, then back to the inlet tract. Im not planning on venting the can to atmosphere.
    You can tap into any point from the IC to the throttle.
    I think several of us here in this thread are confused as to what actually is vacuum and what is atmosphere. If you do exactly as you say here you are still venting the crankcase gases into a ZERO vacuum. There is not vacuum in intercooler pipping, nor is there vacuum in an intake before or after an AFM or MAF. There is only boost and that is all. There is only vacuum AFTER the throttle body. As stated before, You have to connect the crankcase vent to a VACUUM that will draw the vapors out and help with rings ect ect.
    Turbo M42 Build Thread :Here
    Ig:ryno_pzk
    I like the tuna here.
    Originally posted by lambo
    • kamotors
      • Nov 2007
      • 7102
      I dont know why you think it doesn't pull a bit of vacuum at the turbo inlet, the compressor definitely pulls vacuum.
      Put a piece of paper in front of your turbo while idling, it will suck it right up.
      It completely stops backing up of the turbo drain line when draining below oil level(90% of e30 setups)
      all the wrxs hook up right into the turbo inlet.
      here are my many setups, the car runs the best with vacuum to the inlet.
      here is turbo inlet with a catch can
      here is an exhaust scavange kit(they stink)
      and here is no catch can straight to inlet. OEM baffle in valve cover doesnt draw in oil from my experiance
      turbo inlet remains dry after 3kmiles and all pipes are oil free.
      7speedshop.com
      • Dj Buttchug
        • Jun 2010
        • 7688
        i have a really hard time believing that vacuum levels are similar to that of a port behind a throttle body... maybe im confused...
        Ig:ryno_pzk
        • kamotors
          • Nov 2007
          • 7102
          it isnt the same as running at the manifold but it still pulls enough vacuum to give you valve cover a good pull.
          7speedshop.com
          • Dj Buttchug
            • Jun 2010
            • 7688
            I made a stupid drawing only so people wont be confused by our discussion that is completely off track of op haha
            So if you have it routed this way
            How many inches of VAC doesnt that pull? it would have to be very little. like +or - 5 inches? is that even enough?
            Ig:ryno_pzk
            • TheTacoMan
              • Nov 2011
              • 2308
              Originally posted by Dj Buttchug
              The inlet is not vacuum at all. The turbo inlet pulls air from atmosphere. the only place there is vacuum is somewhere behind the throttle body. WTF are you talking about...
              Wait. What?
              The inlet of a turbo has alot of vacuum, how do you think a turbo is able to over come atmospheric pressure?
              • wazzu70
                • Jan 2005
                • 1143
                Im not sure how much vacuum you would get at the inlet, only way to know is to measure it.
                You are right too on the IC pipe, that was a brain fart on my part. You would want to connect behind the TB blade. Sorry about that!
                -Nick
                M42 on VEMS
                • kamotors
                  • Nov 2007
                  • 7102
                  also a check valve is a terrible idea because it wouldnt be able to vent at all under boost, which means a nice smoke show and puked out oil from you valve cover. I've personally seen what not having a decent vent does and in one pull with a closed vent and you'll get a decent amount of oil pushed out of the valve cover gasket and sprayed all over your turbo/manifold.
                  7speedshop.com
                  • Dj Buttchug
                    • Jun 2010
                    • 7688
                    Originally posted by TheTacoMan
                    Wait. What?
                    The turbo inlet is sucking air through a cone filter. Theres just very little area to create anything substantial is seems because the connection for the crankcase vent is so close to open air (the cone filter)
                    I dont know, maybe Im over thinking this. I really want to know how to do it correctly as it may fix my idle issues on my turbo m42. If the way Kamotors has it routed works, then shit, im all for it. I guess the only way would be to measure Hg of vacuum at that location and report back.
                    When an engine is decelerating the vacuum created by the intake is well into 21 inches.
                    I suppose this is the kind of vacuum that is needed to help engine internals operate properly which was briefly discussed earlier. This is what I am most interested/ concerned about.
                    Ig:ryno_pzk
                    • kamotors
                      • Nov 2007
                      • 7102
                      most car run the PCV straight to the turbo inlet from the factory so I dont see why it wouldnt work on an E30.
                      Turbo's draw in LOTS and LOTS of air, more then enough to suck globs of oil out of your valve cover without a baffle.
                      7speedshop.com
                      • Dj Buttchug
                        • Jun 2010
                        • 7688
                        technically the air coming from the crankcase vent is "metered air" right? by that I mean air that has been see by the AFM or MAF as air that should be burned in a mixture?
                        Ig:ryno_pzk
                        • kamotors
                          • Nov 2007
                          • 7102
                          you may be over thinking it.
                          I believe even on the 324td BMW vents valve cover to turbo inlet.
                          dinan
                          7speedshop.com
                          • Dj Buttchug
                            • Jun 2010
                            • 7688
                            interesting. I will be routing mine this way and see if it helps.
                            Ig:ryno_pzk
                            • torell
                              • Dec 2012
                              • 8
                              i would go with straight to athmosphere option rather then routing it to turbo inlet. Why? Your turbo will live longer without a sludge on core. There is also a risk that with high boost level pressure in crankcase will increase and you can suck some amount of oil thru cover straight to turbo thats why c.can for oil is recommended.
                                • 34847
                                all OEM turbos route it to the turbo intake. another option is to scavenge some vacuum in the downpipe.
                                You want vacuum in the crankcase. Not only does it help things like rings seal, it keeps your oil seals happy. the catch can method is ghetto.
