M42 cooling help
  • Dj Buttchug
    • Jun 2010
    • 7688
    has it been excessively overheated before?
    Turbo M42 Build Thread :Here
    Ig:ryno_pzk
    I like the tuna here.
    Originally posted by lambo
    • Austin30
      • 61
      It doesnt really go down while im drivin but idk because ever sense this problem i can tell because its just keeps bubblin out when i have the cap off the radiator. I would love to jet get a new head and a head gasket kit but nobody around here has a head or head gasket kits.
      91 318is
      94 accord
      96 mustang / workin progress
      sigpicE30 enthusiast
      • Austin30
        • 61
        I blew the head gasket once from overheating and shaved the head and put new gaskets on. Drove it for about 2 years and this has happend.
        91 318is
        94 accord
        • bmwman91
          • Oct 2004
          • 3134
          You should see about getting an exhaust gas vapor test kit. It's a little disposable chemical test that you basically connecto to your expansion tank fill hole and it'll change colors if there are exhaust gas byproducts present.
          If it was overheated, there's a fair chance that a crack developed around an exhaust valve guide.
          Head gaskets and stuff are readily available at Pelican Parts and other places. As for the head, you could get a used one from another member or see about having yours welded. Assuming that's the issue anyway.
          Transaction Feedback: LINK
          • kwill22
            • Apr 2009
            • 962
            That test doesn't always work. When my head was cracked I did the test because we had one laying around at work and it never gave me an indication of exhaust gas. I held it to the actual exhaust after to make sure it was good and the color changed.
            If you're seeing bubbles in your overflow there's a good chance you have a crack in the head. When I overheated mine. I pretty much did what you did, replace gaskets ect. And it took a year and a half for symptoms to show up. My compression numbers were also normal. Go figure
            DENY IGNORANCE!
            Schwarz 325-totaled
            brilliantrot 318i-daily
            Originally posted by mkcman17
            don't think your hamster wheels are fast now. you will still have to give up when trying to pass that V6 odyssey to make your offramp.
