Best way to access block coolant drain?
  • firstE30
    • Oct 2013
    • 98
    Hi all. I am trying to flush the nasty brown coolant out of my m42 but i cant seem to get the block coolant drain plug out. I have tried going at it with a crescent wrench and a 19mm ratchet with extension but it is on their pretty good and i cant get in a comfortable position to really leverage it. How the hell do i get that plug out?!?
  • bmwman91
    • Oct 2004
    • 3134
    19mm socket and the right extension on a ratchet. Can you get a better angle on it from under the car? Yeah it is a shitty location. Soak it with PB blaster and let it sit for an evening.
    Transaction Feedback: LINK
    • TobyB
      • 5251
      This is one of those 'just the right length' extension things- when you have the
      right length one on the right socket- or breaker bar- it comes right out.
      Otherwise it's a total bitch.
      I've pulled more than one to find it's so silted up that water won't come out...
      And they can get really really stuck, too, sometimes.
      t
      • hachirokuae
        • Jul 2013
        • 24
        t
        The same thing happened to me. Nothing came out, and after i looked closely there was no hole behind the bolt thread
        • roguetoaster
          Biggus Tippus
          • 7830
          If that happens, just take a screwdriver and jab at the blockage until it clears. A hammer may, but out not be required.
          • hachirokuae
            • Jul 2013
            • 24
            From which side of the hole does it pour out, because I cant see the passage.
            • roguetoaster
              Biggus Tippus
              • 7830
              It simply pours out of the hole on the block, don't believe it's more top/bottom/left/right. Be sure you have the right bolt removed (it will be very short, ~20mm total), then insert screwdriver and jab away. At most you will impact the back side of the coolant passage and you are unlikely to hurt anything.
              • firstE30
                • Oct 2013
                • 98
                Im gonna revive my own thread here because i still have not been able to remove the drain plug. Is it olay if i just flush with a hose and drain from the radiator before adding coolant?
                • Dj Buttchug
                  • Jun 2010
                  • 7673
                  yea its a good idea to crack the block drain open. A lot of deposits and what not can only escape from the block drain.
                  Another trick is to add a little heat. Take a propane torch and heat the engine block around the drain plug. The cast will expand a bit and help you break it free.
                  Turbo M42 Build Thread :Here
                  Ig:ryno_pzk
                  I like the tuna here.
                  Originally posted by lambo
                  • firstE30
                    • Oct 2013
                    • 98
                    would a grill lighter type torch be sufficient?
                    • roguetoaster
                      Biggus Tippus
                      • 7830
                      Assuming you mean a glorified cigarette lighter, then no. If you don't want to get a proper propane torch you might try one of those Harbor Freight heat guns or even a mini torch that can be used for cooking applications.
                      • Dj Buttchug
                        • Jun 2010
                        • 7673
                        Ig:ryno_pzk
                        • roguetoaster
                          Biggus Tippus
                          • 7830
                          Better yet:
