dbilas ITBs with turbo, y/n?
  • econti
    • May 2014
    • 1149
    Been offered some dbilas ITBs for cheap.
    Problem is, I'm planning on going turbo and it'd be a bit silly to spend the money and run with them for not long as I was under the impression they do not cope with boost.
    Is that impression correct, or once a plenum has been fabricated, will they actually work?
  • 14''BBS
    • Apr 2014
    • 54
    Just a thought. If your relying on power from forced induction you should concentrate on higher boost levels and quicker spool which is more or less tinkered with on the exhaust side rather then intake/vaccuum, if anything your better off with a custom intake plenum/manifold if you dont think the stock one is up to the task. I imagine tuning might be a little rough especially at idle with an itb/turbo setup
    • bmwman91
      • Oct 2004
      • 3134
      ITBs will cost as much as going FI, for considerably less gain in power. ITBs are all about modifying the intake's resonance characteristics to improve power at the high end, and they can improve air flow across the board in some cases. So, they are really intended for NA applications in terms of the benefit they provide.
      Spend your energy and money on a bomb-proof FI setup. Unless you have money to burn of course, in which case FI with ITBs would be cool lol.
      Transaction Feedback: LINK
      • rturbo 930
        • Dec 2005
        • 2622
        From what I've read, Dbilas ITBs are overpriced junk.
        • econti
          • May 2014
          • 1149
          Yeah, I expected as much. I did want them just for the n/a sound while I build the turbo engine, but can't justify only having them for a few months.
          Thanks lads.
          (I have been offered the remnants of a beast turbo setup, and will purchase it, so stay tuned for hairdryers)
