m20 clutch/FW conversion question
  • reyesch3
    • Mar 2013
    • 103
    thanks for the comments, I just got everything needed, hopefully car is running by this weekend
    praying the rattling isnt too bad i dont like any car making werid sounds
    • dude8383
      • Jan 2005
      • 10387
      This is one of best upgrades to do to an m42 318i/318iS... pair it up with a markD chip and it'll make the car feel nice and peppy!!
      • varg
        Florida Turbo Man
        • May 2014
        • 3440
        Originally posted by reyesch3
        What clutch do your recommend?
        I can't recommend the cheap ebay clutch I bought, haven't had problems and it's holding fine with 16psi of boost, but I wouldn't recommend cheaping out on a clutch.
        IG @turbovarg
        '91 318is, M20 turbo
        • Gerta
          • Sep 2009
          • 2119
          I ordered the Sachs kit from Blunt. If you shoot him an email with what you want he can get it all packaged up for you.
          Parts Collector and Former Houndstooth interior junkie.
          • reyesch3
            • Mar 2013
            • 103
            So I fitted everything in like it suppose too, but the flywheel doesn't clear, I think it's rubbing against the housing.
            Do I need to machine or resurface the flywheel in order for it to fit?
            • reyesch3
              • Mar 2013
              • 103
              it was making some type of rubbing or grinding noise
              • vpilarrt
                • Jun 2006
                • 2096
                Just to double check; did you put the spacer ring off the M42 flywheel between the crank and the M20 flywheel?
                • reyesch3
                  • Mar 2013
                  • 103
                  yeah i forgot about that, its all good now. it took a little getting used too but
                  i got it up and running, feels a lot faster in those first gears, but then again i haven't driven the car in months.
