M42 Valve cover?
  • E30Brad
    • Aug 2013
    • 84
    M42 Valve cover?
    This part's gasket is decaying into my motor. The part# doesnt exist in bmw archives. Im not buying a new valve cover. PART#11121721873
    Anyone ever deal with this?
    NOT MY PHOTOS.
  • roguetoaster
    Biggus Tippus
    • 7830
    Yes, it's the oil separator. Since new gaskets are not available or listed you just have to make a new one yourself. This can be done with most any oil resistant gasket material available online.
    Once you install a new gasket you'll probably find that you have less oil in the hose to the TB/on the throttle plates.
    • DER E30
      • Sep 2013
      • 2347
      Gasket maker??
      -Christian
      • E30Brad
        • Aug 2013
        • 84
        Thanks guys, glad im not the only one. My main concern was the oil making its way back into the intake.
        This part should be available!!
        • roguetoaster
          Biggus Tippus
          • 7830
          If you dig up a part number do post it!
          • gespinal0301
            • Jan 2011
            • 317
            I changed mine about a month ago maybe less I just called Bennett Auto Supply told them the make, year and model and they had it in stock. Call your local autozones,advanced auto parts to see. When you get the kit it should have the rubber gasket for the valve cover itself, about 12 rubber grommets (one for each bolt, you may have to take some wire cutters and cut the old ones off) and the gaskets for the spark plug wells
            My Daily Driven 318is
            • TobyB
              • 5243
              uhhh, not for the separator plate, they don't...
              t
              • oldmann
                • 265
                I had the same issue with the seperator plate when I swapped engines a couple weeks ago. I didn't like the looks of the rubber peeling off the edges.
                I took it out and scrubbed, with a stiff brush, all the loose deteriorating rubber off and scraped the edges off, looked fresh when I was done.
                When I first took it out it looked like what you see on a tire that hasn't been cleaned (ever) but it scrubbed off.
                I dont think it will be an issue, if you clean it up real well.
                • E30Brad
                  • Aug 2013
                  • 84
                  Agreed.
                  • thenewguy
                    • 182
                    What exactly does this separator do?
                    • Dj Buttchug
                      • Jun 2010
                      • 7672
                      It keeps oil from splashing up off the cams and getting into the intake.
                      Can the engine run without the plate?
                      Yes
                      Does it is suck without it?
                      No, Not really.
                      Turbo M42 Build Thread :Here
                      Ig:ryno_pzk
                      I like the tuna here.
                      Originally posted by lambo
