Bogging issues with lightweight flywheel
  • bflan2001
    • Sep 2007
    • 65
    Has anybody else experienced bogging after installing a lightweight flywheel? I went with the E21 M20 flywheel and now I'm thinking it is too light. I have to rev it up to at least 2k before letting the clutch out or it will bog and almost stall. Thoughts?
    Also, why am I reading that M20 starters are hard to find??
  • bmwman91
    • Oct 2004
    • 3134
    Sounds normal. I stalled my car a couple of times after I did the lightweight flywheel swap. It is simple physics...the lighter flywheel stores less kinetic energy, so when you start moving the car you will need to be more careful with the clutch and throttle to smoothly deliver the engine's power to the wheels. Rougher idling, more delicate starts and probably weird rattling noises from the tranny are all side-effects of using a lighter flywheel on the M42!
    Transaction Feedback: LINK
    • roguetoaster
      Biggus Tippus
      • 7830
      Even with the "double M42" M60 I have the very same issue with a lightweight flywheel. It may be annoying at first, but you'll soon get used to it. Frankly, the M42 seems most enjoyable when you wind it out everywhere, so the downsides of a lightweight flywheel are less noticeable.
      Where did you read that M20 starters are hard to find? It's simply not true in the US.
      • reelizmpro
        • 9559
        2k is way too high. How light is the flywheel 6lbs?
        88 M3 - LACHSSILBER
        89 M3 - ALPINEWEISS II
        • bflan2001
          • Sep 2007
          • 65
          About the starters, I was reading on m42club but maybe they were talking about another market, not the US.
          The flywheel is very light, just a hair above 12lbs.
          I'm OK with it I guess, as long as it's something other people have experienced. The engine is definitely happier at high RPMs. I just finished a swap into my E21, haven't quite worked out all the bugs but I'm happy so far.
          • DER E30
            • Sep 2013
            • 2349
            I don't have any issues with mine, give it a bit more gas, you'll get used to it. The first time I drove mine I stalled it first time starting out.
            -Christian
            • packratbimmer
              • Dec 2009
              • 1335
              Yep, you can borrow torque to make horsepower and borrow horsepower to make torque. What you do relates to the way you want to drive the car.
              You can dial it back in with your differential ratio if you like the change.
              • sonomabimmers
                • Dec 2015
                • 802
                i have a lightweight single mass flywheel and have never had to go that high. i can get in gear barely tapping the gas at like 1000 rmp and pull out fine. sounds off to me
                i love bmws
                • MVincken
                  • Sep 2015
                  • 75
                  Than your´s is probably not as light as the topic starter.
                  I could drive away with my original m42 (euro, single mass) flywheel at 1000rpm. can´t do that anymore with a light m20 one
