M42 Full Rebuild now won't start
  • roguetoaster
    Biggus Tippus
    • 7830
    #166
    Wait, I thought you were selling your engine?
    • RobDog
      • Aug 2012
      • 188
      #167
      I don't know shit about M42's, but if this was a M20 I would think the coolant temp sensor or something that controls the mixture while the engine is cold. It seems like once it warms up and the O2 sensor takes over control of the mixture, everything is good. So you may have open loop issues.
      • benz-tech
        • Jan 2011
        • 382
        #168
        I apologize for not reading 12 pages of this thread but you do have the secret o2 wire connector at the fire wall disconnected correct?
        You say "Where are your other two cylinders?"
        I say "Where's your other camshaft?"
        Frankenmotor: if an M42, M44, M20, S50, and S52 were to have a kid.
        • jaredmac11
          • Sep 2007
          • 253
          #169
          For everyone reading, it was resolved page 11 -- blocked exhaust
          It was a bit frustrating to read that you had all these critical components working (i.e. 'fuel is present') when critical tests werent verified (i.e. injectors pulled and verified to be sending fuel). I think you went down so many rabbit holes because of that. You definitely WERENT getting fuel to the spark and thats a critical component. That was figured out at like page 10 lol
          Glad its working....
          edit: whelp apparently you have a whole other issue. good luck.
          • theTBLACK
            • Jan 2013
            • 156
            #170
            Well, it is finally finished :)
            In addition to the clogged cat, the 2 crank position sensors that had been tried were incorrect. So we got an additional known working m42 CPS sensor and it fired right up!
            DONE.
            Founder
            TheDirtyThirty
            instagram.com/thedirtythirty
            • gespinal0301
              • Jan 2011
              • 317
              #171
              DONE.
              Congrats! I've been reading and lurking, but I'm glad that you finally got it. How's the difference from how the engine was before?
              My Daily Driven 318is
              • theTBLACK
                • Jan 2013
                • 156
                #172
                It is so amazing and runs so strong I'm super happy. Now I need a good
                Muffler...
                Founder
                TheDirtyThirty
                • pklym
                  • Sep 2014
                  • 57
                  #173
                  DONE.
                  What was incorrect about the previous two CPS sensors?
                  I'm wondering if we had the same issue...
                  • theTBLACK
                    • Jan 2013
                    • 156
                    #174
                    I tried 3 different brands including Bosch.
                    The one that made it all run was an OEM BMW sensor from a known running m42 with original equipment.
                    Founder
                    TheDirtyThirty
                    • jpod999
                      • Dec 2015
                      • 1401
                      #175
                      Muffler...
                      Years ago I had my stock muffler cut off and a 2.25" in/out Magnaflow welded in. Was quite at first but then it broke into an awesome deep sound. Cheap and sounded good!
                      OBDI M62B44/6 swap
                      Transaction feedback
                      - jpod999
                      • pklym
                        • Sep 2014
                        • 57
                        #176
                        Do you know the part number? My car wouldn't start with new CPS with the part # 12141721504, which superseded the original.
                        I also bought a used OEM CPS (off ebay), part number 12141721968, that did work.
