M42 Full Rebuild now won't start
  • theTBLACK
    • Jan 2013
    • 156
    #121
    Originally posted by varg
    See:
    I'm trying to help you out. Please check that your injectors are getting 12V while cranking before going any further or spending money getting your injectors cleaned.
    I appreciate the help. I will check that first thing Monday and report back. Much appreciated guys really couldn't do it without you.
    Founder
    TheDirtyThirty
    instagram.com/thedirtythirty
    • theTBLACK
      • Jan 2013
      • 156
      #122
      Next steps are to try Varg's recommendation and verify voltage to the injectors. I'm almost convinced at this point this is the issue.
      Today I did pin out every single pin on the DME and everything was in working order, and all of the DME wires to the coils were correct.
      I'm also going to press some air through the fuel lines, make sure the fuel filter isn't backwards, and double check the fuel pressure.
      One thing I worried/concerned about
      Does the fuel pump always prime when you turn the key to the run position? Mine will not do it - even after replacing the fuel pump relay with a known working one.
      I could only get it to turn on by jumping the pins where the relay is.
      If I recall correctly, usually the pump will come on for a brief moment and you can definitely hear it - i'm not getting anything at all.
      Any ideas on that?
      I'll keep you guys posted on voltage to the injector rail early this week.
      Founder
      TheDirtyThirty
      • theTBLACK
        • Jan 2013
        • 156
        #123
        Have you cranked with the fuel rail out (injectors attached) and verified that they are firing?
        The injectors get +12V from the main relay via the red/white wire coming from Pin 87, leading to the harness box under the intake manifold. Verify +12V is present here when cranking. The ECU grounds the injectors in pairs (1&3, 2&4) to fire them. If you haven't, check continuity of the wires between the injectors and the ECU (pins 3 and 32)
        I double checked all of this. There is continuity between the wires and injectors, and I get 12V while cranking.
        Founder
        TheDirtyThirty
        • bmwman91
          • Oct 2004
          • 3134
          #124
          Alrighty, so you get 12V. That is good, at least the supply side is working. Next up you need to check that the ECU is firing the injectors. One pin on the injectors has constant 12V, and the other pin is switched to ground through the ECU.
          It would be hard to check that with the injectors in there, so I recommend buying a small incandescent bulb, like 5W or something, with wire leads and using it as a "mock injector" with the harness. This will quickly tell you if the nodes are being switched.
          Transaction Feedback: LINK
          • varg
            Florida Turbo Man
            • May 2014
            • 3387
            #125
            Just hook up the fuel supply and injector wiring with the rail out of the manifold and watch for fuel spray while briefly cranking it. I don't know if the stock ECU always primes the fuel system unfortunately, I never paid much attention to that kind of thing since I knew I was going to ditch it. If they're not firing, getting 12V, and the harness has continuity, either the injectors are all bad (quite unlikely), the ECU isn't working right (inputs are no good, since the ECU itself is ruled out) or the ECU ground (on the PS strut tower) is bad.
            IG @turbovarg
            '91 318is, M20 turbo
            • theTBLACK
              • Jan 2013
              • 156
              #126
              I did exactly this - I used a 5W bulb and set up wires to make a mock injector.
              The nodes are definitely being switched as it the bulb flashed while cranking. So I believe the injectors are definitely getting the amount of power they need.
              So i'm thinking either my injectors are clogged, or my regulator is bad. What do you think?
              The fuel pump is new, the lines are new, and the filter is new. I was getting a very steady hose-like stream out of the feed line that goes into the rail.
              Founder
              TheDirtyThirty
              • theTBLACK
                • Jan 2013
                • 156
                #127
                I did this and no fuel was coming out whatsoever. Not even a mist.
                So they are firing and getting 12V, and the harness has continuity.
                The ground on the strut tower is good also.
                So bad ECU or what? Could the injectors be clogged, or the fuel pressure regulator be bad? It seems like if i'm getting spark and everything else that the ECU would be okay.
                Founder
                TheDirtyThirty
                • Balleristic31
                  • Aug 2009
                  • 4198
                  #128
                  You could try pulling the injectors and opening them up with 12v and back flushing them with carb/brake cleaner, then in the regular direction to see if you are getting flow through them.
                  Like stated above though it is very unlikely all 4 injectors are bad/clogged. But it's not unheard of. We're they sitting out for a long period of time before the rebuild?
                  -NICK
                  • theTBLACK
                    • Jan 2013
                    • 156
                    #129
                    No sir. They were in the car and it actually idled (shitty, but it did) before the rebuild.
                    Founder
                    TheDirtyThirty
                    • Dj Buttchug
                      • Jun 2010
                      • 7672
                      #130
                      So where are we at now. Are we back to injectors as the cause of the issue? We gotta figure this out
                      Turbo M42 Build Thread :Here
                      Ig:ryno_pzk
                      I like the tuna here.
                      Originally posted by lambo
                      • theTBLACK
                        • Jan 2013
                        • 156
                        #131
                        Tell me about it.
                        Here is where we are at.
                        Compression is good. Timing is good. Getting spark.
                        Now it's a fuel issue - I pulled the fuel rail and put plastic bags over the injectors - they weren't putting even a mist into the bags.
                        Now we have tested the grounds and all of the electrical with the injectors - everything is working as it should and all the voltages are correct.
                        Not sure what to do next honestly.
                        Founder
                        TheDirtyThirty
                        • bmwman91
                          • Oct 2004
                          • 3134
                          #132
                          OK, well it really does sound like the injectors, or MAYBE the regulator. If the regulator was stuck open, you would still get some amount of fuel pressure in the rail, and then you would at least get a mist out of the injectors. That is what I would think anyway.
                          So, as suggested by Balleristic, you can try directly connecting them to 12V. Don't have them on too long obviously. Maybe listen or feel for a click or other noise to indicate that the solenoid is firing, or if it is off the rail look for the pintle pin to move.
                          • theTBLACK
                            • Jan 2013
                            • 156
                            #133
                            Okay. I'll try that next.
                            Can you speak at all to the issue of the fuel pump not coming on when I turn the key to the run position?
                            Founder
                            TheDirtyThirty
                            • Balleristic31
                              • Aug 2009
                              • 4198
                              #134
                              There should be a very audible "click" when the injectors are connected to 12v and Fire. If you don't hear/feel anything they may be toast. But I have unstuck a few injectors by giving them a CAREFUL but firm whack on a hard surface.
                              Hit them over and over with the 12v pulse and not a constant stream of 12v because that can burn out the solenoid as stated above.
                              -NICK
                              • theTBLACK
                                • Jan 2013
                                • 156
                                #135
                                I just don't understand why they would work before and not now. So weird. I'll see if I can get them to make any noise at all. If not, i'll just get 4 new ones. This is getting out of hand. Well, it has been for quite some time.
                                Founder
                                TheDirtyThirty
