M42 Full Rebuild now won't start
  • theTBLACK
    • Jan 2013
    • 156
    #151
    Last night I installed 4 rebuilt injectors.
    Hooked up the rail - covered the injectors with ziploc bags.
    When cranking, all of them were firing fuel. So the old injectors somehow all went bad at once - or something weird is going on.
    Either way, i'm dropped it off at a trusted shop and i'm let them figure it out.
    I've dumped many hours and too much money into this 4 cylinder motor, hopefully they can figure it out relatively quickly.
    I'll keep you posted!
    Founder
    TheDirtyThirty
    instagram.com/thedirtythirty
    • bmwman91
      • Oct 2004
      • 3134
      #152
      Weird. Maybe the old ones had some bad fuel in them or something and got varnished shut when they were sitting. It sounds like you should have a working vehicle soon!
      Transaction Feedback: LINK
      • theTBLACK
        • Jan 2013
        • 156
        #153
        IT RUNS!
        The exhaust was clogged and it needs a new catalytic converter. The engine couldn't breathe.
        Founder
        TheDirtyThirty
        • bmwman91
          • Oct 2004
          • 3134
          #154
          Lol
          Holy hell, that was unexpected!
          • Gkwan
            • Sep 2015
            • 82
            #155
            I think you owe us a video of it actually running!
            Congrats on getting it running!
            • jpod999
              • Dec 2015
              • 1401
              #156
              Damn, that's backpressure for you! I wasn't far off in my kink in the line suggestion a few pages back, I just had the wrong system!
              OBDI M62B44/6 swap
              Transaction feedback
              - jpod999
              • Dj Buttchug
                • Jun 2010
                • 7686
                #157
                holy ballssssessss
                Turbo M42 Build Thread :Here
                Ig:ryno_pzk
                I like the tuna here.
                Originally posted by lambo
                • theTBLACK
                  • Jan 2013
                  • 156
                  #158
                  Quick update - After taking off the exhaust, the car did in fact run. We didn't rev the motor very high as we couldn't hear the valve train. Anyway, we had a new cat welded in at the exhaust shop.
                  On the way back from the exhaust shop with the exhaust back on - we encountered an issue that we were experiencing before the rebuild.
                  When I first got the car it would run, and idle fine. But upon giving it gas and accelerating up around 3rpm, it would lose power and die.
                  This same problem is now occurring - i'm thinking that the exhaust may be clogged somewhere other than the CAT now as the whole system is aftermarket -
                  I'm going to take off the exhaust tomorrow and see if that solves the problem.
                  I'll get a video tomorrow and share it here!
                  Founder
                  TheDirtyThirty
                  • Cephas
                    • Apr 2012
                    • 878
                    #159
                    Looking forward to the video.
                    Also for others chasing down similar issues: my 89i track car will not prime the pump with the key in the "On" position. Only during cranking. Also, for what it's worth, it will not prime the fuel pump even if I jump it.
                    Good luck with your car!
                    • theTBLACK
                      • Jan 2013
                      • 156
                      #160
                      Anyone still subbed to this thread?
                      The car runs and idles great, but starts to sputter around 2.5 rpm.
                      If you let it warm up for 20 minutes, it revs just fine all the way up.
                      Any thoughts?
                      Thanks guys!
                      Founder
                      TheDirtyThirty
                      • bmwman91
                        • Oct 2004
                        • 3134
                        #161
                        I forget, did you replace the coil packs? They can do weird stuff like not fire if they are failing, depending on if they are hot yet.
                        Otherwise, it sounds like the carbon track on the AFM is going bad. Can you borrow a known good one and try it?
                        • theTBLACK
                          • Jan 2013
                          • 156
                          #162
                          Yup. Coil packs have been replaced. The AFM I replaced it with was a known working one - i'll see if I can get my hands on another one.
                          Founder
                          TheDirtyThirty
                          • Dj Buttchug
                            • Jun 2010
                            • 7686
                            #163
                            running right now?
                            Ig:ryno_pzk
                            • theTBLACK
                              • Jan 2013
                              • 156
                              #164
                              Originally posted by Dj Buttchug
                              running right now?
                              Yes sir.
                              Founder
                              TheDirtyThirty
                              • theTBLACK
                                • Jan 2013
                                • 156
                                #165
                                Anyone still here?
                                R3v facebook has convinced me to keep going and figure this out - even though i'm on mechanic number 3.
                                Current status -
                                Starts and idles perfectly.
                                Upon cold start, won't really rev above 2.5 - Starts to sputter and bounce back like its being limited.
                                Once it warms up for 20 minutes - revs all the way up.
                                Ideas?
                                Founder
                                TheDirtyThirty
