M42 knocking sound. Tensioner?
  • mhuynh
    • Sep 2011
    • 63
    Does this knocking sound resemble a malfunctioning chain tensioner or is it something more serious?
  • vpilarrt
    • Jun 2006
    • 2096
    I don't think its the tensioner. Sounds like rod knock but its a little fast, maybe a collapsed lifter. Does it get more pronounced or change when you accelerate from low rpms?
    • mhuynh
      • Sep 2011
      • 63
      Yes, it's rpm dependent
      • vpilarrt
        • Jun 2006
        • 2096
        Yes but does it get louder? More pronounced?
        • varg
          Florida Turbo Man
          • May 2014
          • 3424
          Still having this problem? Sounds like valvetrain noise to me because of how slow the knock is, a given valve is only actuated once every 2 revolutions on a 4 cylinder engine so the knock sounds slower than rod knock, which is also typically not very loud at idle unless it's a severe case. Post a video with some revving to and sustaining of 2,500-4,000rpm or so.
          IG @turbovarg
          '91 318is, M20 turbo
          • TobyB
            • 5286
            pull coil drivers one at a time, and see if one makes it go away/change a lot.
            over the internet, it sounds rodlike.
            Maybe you'll get lucky and it's an exhaust leak at the head-manifold interface.
            t
