"No Return Valve" ?
  • Steve Corbett
    • Jul 2012
    • 449
    "No Return Valve" ?
    I am replacing the cracked head on my M42, Using a E36 M44 head. Reading the E36 Bentley instructions as the E30 Bentley does not address the M42. It says to make sure the No Return Valve is installed correctly. My M42 appears to never have had one. There is one installed in the M44 Block. RealOEM shows one in the diagrams. Items 9 and 10.
    Steve Corbett
    1983 528E Scrapped
    1983 528E Sold
    1984 745I
    1984 325E - Sold
    1989 325I Bronzit-Sold
    1989 325I Zinno
    1988 635CSI
  • varg
    Florida Turbo Man
    • May 2014
    • 3440
    Mine didn't have one. But the head had been off in the past at some point so I can't tell you if that's a factory thing.
    IG @turbovarg
    '91 318is, M20 turbo
    • TobyB
      • 5298
      I think the non- return valve showed up sometime in E36 production-
      an early parts engine didn't have one, but the 12-94 318i did...
      t
      • roguetoaster
        Biggus Tippus
        • 7830
        I think Toby may be correct as neither of the E30 M42s I've had apart had that valve either when opened or closed back up. If it were necessary to protect the engine I suspect my daily would have grenaded a long time ago, but then I'm not in the habit of taching it out as soon as I start it up.
        • TobyB
          • 5298
          My theory was that it was to somehow reduce lifter leak- down on engines that had
          been sitting for a while. But that was just a guess...
          t
          • Steve Corbett
            • Jul 2012
            • 449
            Thanks for the info. Proceeding without.
            Steve Corbett
            1983 528E Scrapped
            1983 528E Sold
            1984 745I
            1984 325E - Sold
            1989 325I Zinno
            1988 635CSI
            • roguetoaster
              Biggus Tippus
              • 7830
              t
              ...and that's why it's on the E36 and not the E30.
