m42 with m52 flywheel
  • downforce22
    • Aug 2009
    • 3192
    I found a lightweight flywheel for sale on local classifieds. It is a 10 lb flywheel. I am wondering if this will work on an m42 with a g240. Now if I pair this with a stock or m20 pressure plate or clutch, will it work on the m42? It looks like the oem clutch is 228 mm vs 240 mm for the m3 but that shouldn't matter.
    I believe the starter motor ring gear/teeth should work correctly and it should bolt up. Any thoughts or opinions?
    JB Racing 520-10-240
    http://www.jbracing.com/flywheel-bmw5.php
    Fitment:
    1992 - 95 E36 M3 w/ S50 3.0L - 6 cyl.
    1995 - 99 E36 M3 w/ S52 3.2L - 6 cyl.
    Lightweight Aluminum flywheel replaces stock dual-mass flywheel. Accepts OEM clutch/pressure plate/throw-out bearing components as well as performance aftermarket direct replacements. Will also accept many aftermarket sprung-hub clutch discs. Provides improved throttle response and increased performance. For a complete flywheel/ sprung-hub performance clutch kit - see PN 520-010S-S855
    520-010-240 Clutch Diameter: 240mm OEM Flywheel Wt. 25.0 lbs.
    List Price $646.00 Alum. Flywheel Wt. 10.0 lbs.
  • bmwman91
    • Oct 2004
    • 3134
    Based on RHD's site, the M4x and M5x engines (not M54) can all use the same flywheels and 228mm M20 clutch parts.
    https://racehead.com.au/product/bmw-...254-m40424344/
    I just recently received my RHD flywheel, and at 7.4lbs it's going to be a ride lol.
    Transaction Feedback: LINK
    • downforce22
      • Aug 2009
      • 3192
      thank you, that is helpful to know!
      • TobyB
        • 5286
        ...buut, you'll need to use a 240mm clutch and pressure plate with the JB Racing flywheel.
        As it's for an M3.
        M20, M42 and M5x are dimensionally the same, as far as the flywheel is concerned.
        t
