Missing Sensors on Getrag 260?
  • jnbentley26
    • Oct 2020
    • 12
    I purchased a 1989 325i from a guy who treated it horribly and am now doing a clutch replacement. When dropping the transmission I noticed 2 empty holes on the side of the bell housing that look like they should have sensors. From my research I believe these should be the engine speed and reference mark sensors. I see no cables dangling from the engine bay and cannot find any diagrams or videos online about where to connect these sensors. Should there be sensors in these holes? I have noticed the car seems low on power and am wondering if this could be related to that issue.
  • jnbentley26
    • Oct 2020
    • 12
    Did some further digging in the Bentley manual and found that only 84-87 325e and es models had the testing reference and speed sensors with the 88-90 325i and is models having the testing pulse sensor in the engine bay. Should there be a cover of any kind over the two sensor holes on the transmission? Looks like I’ll have to keep looking for my power loss issue
    • AWDBOB
      hooptie connoisseur
      • Aug 2013
      • 4516
      No cover- your car has been manual swapped (or someone just replaced a bad trans) and they used a transmission from an early e car.
      I've seen folks leave the old sensors bolted in there to seal the holes up. It's not the most elegant solution, but it works.
      • 82eye
        • Jan 2009
        • 2109
        there are blanking plugs available.
        • Panici
          • Dec 2009
          • 2576
          That's what I did when I had a G260 in my car.
          I cut the wires off the sensors as well.
          • jnbentley26
            • Oct 2020
            • 12
            The previous owner definitely poorly swapped it, it’s missing bell housing bolts. I don’t have the sensors to plug the holes, will it cause issues to leave them open? Thanks for the response!
            • Panici
              • Dec 2009
              • 2576
              Will be fine to leave them open.
              There is technically a chance of foreign objects getting inside the bellhousing, but I've seen plenty of "inspection holes" drilled through and left open.
              A lot of older Ducati motorcycles have a dry clutch (like a car) and run open clutch covers without issues.
              • PEZ2
                • 50
                I just cut the sensors wires and left in place. BMW lists a plug part p/n 21111225047
