I been searching for solid rubber mounts. I know bmw use to sell solid rubber mounts. I don’t want to buy poly mounts. IDoes anyone know where can I buy solid rubber mounts.
I have done Powerflex soft polyurethane for around $40-50. It's 2 pcs sandwiched between 2 large washers. Very easy installation, great fit and I didn't notice an increase in vibration or noise. People have been reporting that certain replacement OE rubber bushings are actually larger in diameter and are breaking the diff cover when they press them in. So definitely check the bushing if it needs to be pressed in.
Thanks Barry.
I ordered two AKG blue 85A poly bushings for my Hartge project. I running Hartge dual diff mounts.
