Diff Cover Ruined?
  • Nohawkscott
    • Apr 2025
    • 40
    Diff Cover Ruined?
    I had to get pretty barbaric removing the stuck steel ring from the old bushing. I’ve sanded down all burrs but does this gouge make this thing a write off.
    im installing a 80a garagistic bushing if that matters..
  • McGyver
    • 4633
    Send it.
    That little knick won't do anything, especially with a poly bushing that slides in by hand. Worst case scenario is the ring splits and the diff thumps around until you fix it. The diff is bolted to the subframe, so it isn't going anywhere.
    • Nohawkscott
      • Apr 2025
      • 40
      Done. Thank you👍
      • 82eye
        • Jan 2009
        • 2045
        it's not worth the nvh for a road car imo. as mentioned, that nick won't hurt it at all.
        • Nohawkscott
          • Apr 2025
          • 40
          I’ve heard that nvh will increase but I’m hoping it’s not too bad. If it is, I’ll swap it for rubber when I pull the subframe out for refurbishing next spring. I’ll know by then if there are any issues with this lsd too.
          • 82eye
            • Jan 2009
            • 2045
            good plan.
            • TobyB
              • 5263
              I too endorse this plan. I found that a hard diff bushing was telling me more than I wanted to hear about what was going on in the rear gears...
              The E36 diff cover conversion always made a lot of sense to me, too, but I haven't tried it yet.
              t
