How does this Getrag 260 look?
  • rmdashrf
    • Feb 2014
    • 207
    Originally posted by SpecM
    Do it right or do it twice ;)
    QFT.
    I also would not use that disk.
    • Panici
      • Dec 2009
      • 2528
      Alright, thanks guys.
      Looks like I'm doing an entire clutch replacement basically. That's going to more then double the cost of this swap though :(
      But it's such a PITA to drop the trans. Like you said, do it right or do it twice.
      • Wanganstyle
        • 2828
        Do it right or do it twice. Change out the clutch with new parts
        I could only see the pressure plate and friction disc used in lemons racing; this is one situation where nothing is done right and depending on team the engine will blow up every 8-12 hours average.
        Lemons racing.... where clutches sometimes outlast engines. Everything blows up
        • Panici
          • Dec 2009
          • 2528
          Any suggestions for kits that might have all the parts I need?
          It looks like my '86 325e (that this trans came out of) is a single mass flywheel?
          I though ETA motors had dual mass?
          • Panici
            • Dec 2009
            • 2528
            After some searching, it looks like the ETAs made before a certain date were single mass, as mine is.
            Does anyone know if I need to keep the step in the flywheel when it's machined? What's the step height I need to tell the machinist?
            Thanks!
