Cost on e30 5 speed swap?
  • Mr. Tasty
    • Jul 2011
    • 3421
    Originally posted by 808e30325i
    Parts alone are around $700
    It can be pieced together with new OEM maintenance parts for around $500. You just need to keep an eye on the deals. It is very similar to building a nice computer rig. Don't jump right into it, or you will spend much more than what is needed.
    2014 Alpine White 335i MSport
    (Daily Driver)
    Full Mperformance Aero
    KW V2 Coilovers
    VRSF Catless Downpipes
    • Poorboyz
      • May 2012
      • 2117
      My buddy bought a beat up E30 5 speed for $300, got all new seals for trans, fluid, new rubber parts, new clutch and slave, etc...He spent about $700 total. We did the swap 2 weeks ago and took us 8 hours. Neither of us had done one before. I'd have to say the worst part (for me) was the pedals.
      Rebuilding since 07/06/2016
      Poorboyz Parts For Sale - Updated 01/20/17 - Will be updated soon - Have many parts to post
      Poorboyz Feedback Thread
      • jwiles
        • Jun 2012
        • 200
        ^completely agree 700 is a safe number if you find a deal on tanny like that. other wise if you go to bava and decide to fist your self your going to be looking at about 500 in replacement parts. little tic tac stuff that adds up. the swap doesnt take long at all. once the down pipes are out of the way.
        hell idk sometimes you just have to wing it. JW
        • AwakenNoMore
          • Dec 2010
          • 1291
          I'm going to be spending about $1k. I already have my clutch kit, trans, pedals, driveshaft, hydraulics and shift linkage. Still have to grab a flywheel and tons of small preventative maintenance bits.
          1991 325i - "Scambles" The Daily Driven lightly modded.
          1988 Mazda RX-7 TII "Mako" The Free Dorito
          bacon by Jared Laabs, on Flickr
          • RondoAcapriccio
            • Jul 2011
            • 524
            It depends on location and parts availability but here is a general breakdown.
            5 speed swap sold on forums - approx 400-600... consider 800 shipped.
            That's the bare minimum if you do your own labor.
            Then if you want to refresh the consumables... budget another 600 or so... so you are looking at around 1400 if you do the labor.. add another 500-800 if you pay a shop.
            That's the truth.. I'm not going to bullshet you about finding deals here and there. Sure you might find one, but you might not. Also I don't think I would want to spend the time in the JY pulling the parts, so I'd rather buy it on the forums.
            • 325ESFTW
              • Nov 2016
              • 1
              E30 manual swap
              It depends on location where you live and if your able to do your own work on your car.. I just went today to the salvage yard and got the whole manual swap for the E30 for $300.00 ..that includes transmission ,pedals,master and slave cylinder,transmission,clutch,flywheel,shifter with all hardware,and driveshaft.. plus manual transmission subframe and mounts ..
              • c0rbin9
                • Dec 2015
                • 609
                As a general rule, it is more expensive than what everyone on here will tell you.
                1991 318is Brillantrot daily driver (slow restoration)
                • TobyB
                  • 5213
                  Or rather, we are all optimists...
                  t
                  • SoEm0
                    • 449
                    Mine was around $550-600. Got the trans and drive shaft from local pick n pull for 180. Found a fly wheel at a different jy. New clutch and pp. Local machine shop hooked me up and lightened my fly wheel and balanced it with my pressure plate for 50
                    Sent from my LG-H900 using Tapatalk
                    CCW- when every second counts... The police are just minutes away!
                    • straight6pwr
                      • Sep 2004
                      • 3450
                      to do it properly? budget $1500
                      lot of people here seem to have a bragging tone on how they did it so cheap with super deals, and 'got the hook up' and the like.
                      there are some many more little parts involved in this than trans/driveshaft
                      you should really get a lot of new parts, not just take the junk from a yard. you don't want to redo all that work!
                      new stuff should include:
                      clutch master cylinder
                      clutch slave cylinder
                      clutch rubber line
                      flywheel (maybe reuse)
                      clutch
                      trans throwout bearing
                      trans input shaft seal
                      engine rear main seal
                      guibo
                      center support bearing
                      exhaust hardware
                      all your shifter bushings
                      new transmission fluid
                      ...i'm sure i'm missing stuff
                      i did a 5sp swap on my e34 touring and did all these items. its nice to know i will have no reason to pull the trans for years and years.
                      • N2MYE30
                        • Oct 2007
                        • 5536
                        Used G260, driveshaft, pedals.
                        Turned flywheel
                        New clutch kit
                        Everything else new
                        <$950 and did it in my garage on stands.
                        COTM
                        • Blackthorn
                          • Sep 2016
                          • 125
                          Well im in the middle of one on my new shell. I picked up a rust bucket 89is that ended up having been in a worse rear end accident than i was willing to work with. Picked up an auto 91i for my doner shell (motor was done). The 91 had been sitting for 15+ years so i needed to replace a few parts but i picked clean that 89 for the parts i needed for my swap. If you refresh everything (like most will tell you to do) it can get expensive.
                          But im right now out 900 for both of the cars. Which gave me a working motor, 5 speed swap, LSD, and various other bits. Then i replaced the TB, WP, Gaskets, plugs, center support bearings, and picked up a complete bushing kit from Condor. The parts set me back about 600 which the majority of it was the full condor bushing kit (400). If you have the patience id just call around the local junkyards.
                          LKQ here in texas i would pick up the support parts (pedals, driveshaft, shift linkage, and various aux parts) for under 120.
                          Id pick up a used 5 speed from a place that give you a warranty for 2 - 300 bucks. I payed 275 for mine as i thought my 89is had a bad tranny.
                          Then your going to want / buy new the clutch, master, and slave cylinders. Which will run you about 3-400 bucks.
                          For all that your putting into the car id probably just do a motor swap with a compatible 5 speed. Like a m / s52 with the zf 5speed which directly fits into our cars. Your still going to have to pour some money into refresh parts but you get a whole lot more for your money.
                          This site is a great place to handle this kind of job yourself. Dont pay a shop 1000s of dollars for something you and a mechanically inclined buddy can handle in a weekend. If you were here in Houston id say drop on by and see how easy it can be.
                          • Eric Giles
                            • 1068
                            I just completed a manual transmission swap this past weekend on my newly acquired '87 325is. It had an automatic transmission that had failed, and I originally just bought the car for the interior- but I needed it to be movable in the meantime. I intentionally went the least expensive route, and found someone relatively local that was parting out an e30.
                            I got everything I needed for $450. The clutch had plenty of life left, so I reused it. I spent less than $50 on some new minor maintenance parts that needed replacing.
                            It proves it can be done cheaply, BUT.... normally I would NEVER do this swap without at least using a brand new clutch kit at a minimum if it was a car I planned to keep.
                            Sent from my Pixel XL using Tapatalk
                            Eric Giles
                            '20 M2 CS
                            '04 M3
                            '11 X5 35D
                            '87 325is
                            '91 325i Sport
                            There are few things more expensive than a cheap BMW...
                              • 34839
                              Every pu$$y these days wants an automatic BMW - "the paddle shifters are just like a manual", "ATs are faster anyway" (ok Michael Schumacher).
                              The point is, no E30 deserves an AT - you gotta make it happen. ;)
                              • jeffnhiscars
                                • Jun 2011
                                • 6010
                                I bought a swap kit from Matt (ragtope30) including new hydraulics. He had the donor in his shop so it was a no brainer to bring the car to him. I brought new clutch, csb, guibo, trans bushings and seals, fluids, AC cable, rms, pan gasket and RHD 7 lb flywheel. etc
                                We did it in a very long day and I'm in for right around $2k.
                                I highly recommend getting a complete kit rather than trying to piece it together.
                                Ps he just sold my old trans today so I'm getting a rebate :)
                                Alice the Time Capsule
