Replacing output flange
  • Calypso Moor
    • Sep 2013
    • 91
    Need to replace the output flange on my Getrag 260 and I need to know what other parts I'll need/ought to replace while I'm down there, anyone on here know? According to the Bentley, it looks like the lockplate gets mangled during removal. What about the securing plate, stop disk, and whatever #16 is in this picture?
    http://realoem.com/bmw/showparts.do?...94&hg=23&fg=15
    and some anyone know where I could find some of this stuff? I found the securing plate easy enough, but can't find the lockplate anywhere.
  • reelizmpro
    • 9552
    I honestly don't remember having to change those when I swapped flanges a few years back.
    88 M3 - LACHSSILBER
    89 M3 - ALPINEWEISS II
    • TobyB
      • 5280
      Hmmm- #16 looks like your speedo drive gear... which certainly doesn't apply!
      Nope, swap the flange and lockplate, and off you go. However, since you're in there,
      it seems silly not to swap the oil seal too. Pain to get out, much easier to install
      with the right size piece of PVC pipe...
      t
      • Calypso Moor
        • Sep 2013
        • 91
        t
        Toby, do you know the part numbers for the lockplate and oil seal?
        • TobyB
          • 5280
          www.penskeparts.com would be where I would look...
          t
          • Calypso Moor
            • Sep 2013
            • 91
            do you know what the p# for the oil seal is?
