splitting a getrag 260
  • Axxe
    • Aug 2004
    • 3355
    Originally posted by spdracrm3
    you'll have to remove the input bearing from the input shaft(press needed with bearing splitter) to re-assemble case halves and then press the bearing back into the case/onto input shaft with heat and yet more special tools once case halves are back together,and not damage the case or input shaft/syncro hub(can't just drive it on with a hammer as it will compress the syncro hub)
    i have the Factory manual if you want to look at it
    I would be interested in this. We have one trans that lost 4th gear, and another with a broken tailstock and leaking input shaft (can't get a seal to hold, surface pitting on shaft from sitting outside). If I could make 1 out of 2 that would be great, we have another 2 spare trannys lined up so this will be an off season "always wanted to do that" project.
    Keep it slideways!!
    • spdracrm3
      • Sep 2009
      • 959
      you'll have to come to Colorado if you want to look at the manual
      i have a link to the factory TIS /manual online but it doesnt show trans dis-assembly
      Angus
      88 E30M3 X2
      89 325IX
      92 R100GS/PD
      • Dirty325ix
        • Sep 2012
        • 689
        I have made my own bmw tool out of some piping and am splitting the getrag just like this
        Damn that video and the bently made it seem so easy
        So your in castle rock? I'm in denver, I might have to take you up on that offer and check out that manual. All I have is the bently and so far have followed the first few steps but either the bently or I seem to be missing a step
        Btw I seem to have the exact same problem you had before( ix manual trans stuck in reverse)
        • spdracrm3
          • Sep 2009
          • 959
          just moved to Castle rock 1 month ago ,still settling in ,let me know if you want to stop by see some of my collection and shoot the breeze, or if you want help , have quite a few tools too
          yup its a common problem (got my IX cheap because of that), be sure to check the allen bolt up on top and as your splitting the case i would remove it and Red loctite it . i did that to mine and the Z3 shifter upgrade ,new seals and its dry, tight and no shift problems in 20k miles
          Angus
          88 E30M3 X2
          89 325IX
          92 R100GS/PD
          • TobyB
            • 5280
            That puller is F&*#ING BRILLIANT! Mind if I steal the idea???
            t
