LSD identification
  • E30arian
    • Apr 2013
    • 305
    LSD identification
    Any idea what LSD I have, I can't tell from the tag
    Sent from my SM-G900T using Tapatalk
  • flyboyx
    • 8371
    no. not by looking at that one.
    your best bet is to take off the rear cover, count the teeth on each gear, and divide the big number over the little one.
    the next best would be to spin the pinion shaft and count the rotations of the axle shafts.
    Gigitty Gigitty!!!!
    • TobyB
      • 5298
      Well, it LOOKS like a diff tag, but it lacks the right NUMBERS to be a diff tag.
      I'm with Flyboy, but I'd just count the revs. It's not an ix diff, is it?
      t
        • 34847
        Maybe its coincidencs but 4873 / 1141 = 4.27
        • flyboyx
          • 8371
          i like the way you think but what e30 came with that ratio?
          perhaps a manual 318i cabrio with cold weather package? i've had a few of these over the years and can't recall if it was 4.27 or 4.29
          i guess it would be a good idea to just ask the op what vehicle it came out of?
          Gigitty Gigitty!!!!
          • george graves
            • 20003
            The S at the end is an indication of it's an LSD.
            Originally posted by Matt-B
              • 34847
              318I convertable i think?
              • TobyB
                • 5298
                4.27 was in the auto '91 318i softtop, it's true. Small case, tho.
                t
                • E30arian
                  • Apr 2013
                  • 305
                  Hioooo
                  • Northern
                    I like cupcakes & sh!tboxes
                    • 5288
                    If it's a 188, take the cover off, look at the markings on the ring gear:
                    Originally posted by priapism
                    Originally posted by shameson
                    • lukeADE335i
                      • Apr 2013
                      • 1389
                      I'd suggest it's likely a 4.27, but the easy way to see if that's around the mark is to turn the output shafts and see how many rotations the input shaft does.
                      Easier than tearing the diff apart to get a quick idea.
                      My e30: OEM+ with M30B35
