Help With Lubrication
  • crackerbme
    • Aug 2017
    • 5
    Hey guys, I need some info on oil for my transmission and differential. I have an '89 325I and I have fully rebuilt the 5 speed transmission with new bearings and sycros and the LSD differential with all new clutch plates, dog ears and ramps, and I am having a difficult time selecting the fluids for them. Should I use fully synthetic or not? What would be the weights of the oils that I should use? I have read that one person used Redline synthetic and it ate up his syncros, is that even possible?? I have 6 new sycros in there at a hefty price so obviously I don't want that to happen. Any help or information will be a big help. Thank you.
  • flyboyx
    • 8371
    Red line fluid did not chew up someone's syncronizers. They are passing blame off of their own sub par workmanship.
    Do you have a bently service manual? This book is the maintenance bible for the e30. It will tell you the correct viscosities for every location on your car. I would personally use only synthetic fluids in my car. Shell and mobile make great products. I would personally avoid bullshit botique companies like royal purple that charge about double for the pretty color. I dont have any experience with red line, but i would choose products from the ones i mentioned above.
    Welcome to the forum.
    Gigitty Gigitty!!!!
    • jeffnhiscars
      • Jun 2011
      • 6011
      The risk to synchros is not connected to synthetic vs Dino but rather the additives. As long as you stick w GL4 you should be fine. It's the GL5 that eats synchros (& small children).
      I use redline MTL in the trans and redline 75-90 in the diff (you'll want the lsd version of course). Assuming you're in the St Albert in Alberta both of those should be thin enough for winter.
      Alice the Time Capsule
      • UNHCLL
        • 8790
        Red Line has a reputation with racers and enthusiasts alike for creating products that perform and protect better than any on the market. No compromises.
        Gearbox - Redline MTL
        Differential - Redline 75W90 GL5
        Below the radar...
        • Digitalwave
          is a poseur
          • 6299
          Originally posted by UNHCLL
          https://www.redlineoil.com/application.aspx
          This.
          RISING EDGE
          • YosemiteSam
            • Apr 2011
            • 1303
            This.
            Those two guys.
            • jeffnhiscars
              • Jun 2011
              • 6011
              There's an echo in here
              • parkerbink
                • Jun 2004
                • 10138
                One of the several threads like this ought to be a sticky.
                • roguetoaster
                  Biggus Tippus
                  • 7830
                  But not this one, as not one member here turned the thread in to a sophomoric sex joke.
                  • TobyB
                    • 5280
                    Sticky
                    Better?
                    t
                    • dnguyen1963
                      • Nov 2011
                      • 2651
                      I was just thinking about a different lubrication. How about that?
                      • Joe G
                        • 2942
                        I'm here for the gang bang, brought my own lube too.
                        Current Car: 2011 BMW 135i, M-Sport, 6 speed
                        Originally posted by lambo
                        Sounds like you need a massage.
                        Originally posted by kpeng
                        Who the hell is Vlad?
                        • roguetoaster
                          Biggus Tippus
                          • 7830
                          Why are you banging gears? Use the clutch or r3v match next time.
