Stripped Differential bolt
  • franan
    • Sep 2016
    • 35
    How to remove a Stripped Differential bolt. So today I went to change my differential fluid in my new 1989 325is and when I got under the car guess what I found..................the idiot that owned the car before me apparently tried to change the fluid but STRIPPED both the fill bolt and drain plug. Is there anyway to get these damn things out thank you?
  • ForcedFirebird
    • Feb 2007
    • 8300
    Small pipe (monkey) wrench does the trick.
    john@m20guru.com
    Links:
    • jeffnhiscars
      • Jun 2011
      • 6011
      I think its more likely the cover is stripped and not the bolts. Either way i think its easier to resolve with the cover off
      Alice the Time Capsule
      • ForcedFirebird
        • Feb 2007
        • 8300
        He said it's the plugs. They have a "nail head" shape and a pipe wrench will grab them. And based on the fact that the PO stripped them, they are probably over torqued to boot. Might be wiser to leave it in the car for leverage.
        john@m20guru.com
        Links:
        • e30davie
          • Apr 2016
          • 1788
          Depends if you have a large enough vice to put it in on the bench i suppose.
          Id they are indeed that badly stripped, step 1 is buy new plugs so when you eventually do get it out you can put new ones in:D
          • Echo30V
            • Sep 2017
            • 301
            So, Are the torx heads stripped out so when you put the torx socket into plug it just spins or did the idiot over tighten them into the rear diff cover and the whole plug is spinning?
            If it’s the former you can try two things and one will work. If you can get in there with a chisel and hammer, hammer a nice dent into the side of the plug, then angle the chisel towards the left and hit the bolt in the dent so it spins left. OR take a Dremel and grind an x into the plug head then try a large screw driver.
            • jeffnhiscars
              • Jun 2011
              • 6011
              Why not just replace the cover
              • Echo30V
                • Sep 2017
                • 301
                I think they are going for $150 to $200?
                • ForcedFirebird
                  • Feb 2007
                  • 8300
                  No. I have pile of them if you want to go that route, maybe $150 powder coated, new gasket and plugs lol.
                  Yes, have spare plugs on hand before going further at the least in case you ruin them.
                  john@m20guru.com
                  Links:
                  • jeffnhiscars
                    • Jun 2011
                    • 6011
                    Notmto undercut my friend John but I've got one here (not powder coated) somewhere that I'd sell for $40 plus shipping.
                    • franan
                      • Sep 2016
                      • 35
                      Echo30v It just spins the idiot over tighten them Yes.
                      • ForcedFirebird
                        • Feb 2007
                        • 8300
                        Why you...J/K. Yes, $40 is more like it.
                        john@m20guru.com
                        Links:
                        • Echo30V
                          • Sep 2017
                          • 301
                          Then I would agree and just buy a replacement cover from jeffnhiscars for $40. I would think that you will damage the cover to the point of no return if you tried to remove the bolt. I quess you could try to drill it out and carefully retap it but you will probably ruin the cover.
                          • zaq123
                            • Jul 2016
                            • 1560
                            +1. $40 for the cover? you got off easy if you go that option. Freaking plug is $7 ea
                            • jeffnhiscars
                              • Jun 2011
                              • 6011
                              I didn't say it had plugs :)
