Is the Getrag 260 5 speed the same got the 325e and 325i?
  • Whitten
    • May 2018
    • 3
    Hey, i was wondering if a Getrag 260 5 speed was the same a cross the bored for the e30s. I am looking to do a manual swap and want to make sure the bell housing would fit right up from a 325e to 325i. i would think they are the same transmission.
  • ForcedFirebird
    • Feb 2007
    • 8300
    Same transmission. Just be weary that some of the earliest eta getrags came with only the sheet metal shifter mounts, the later style with the aluminum carrier is preferred.
    john@m20guru.com
    Links:
    • Reichart12
      • Aug 2012
      • 2165
      Also isn't the 325e bellhousing deeper to account for the dual mass flywheel? When I swapped engines from 325e to 325i and to a singlemass flywheel while retaining my 325e trans, I needed the longer throw out bearing from a euro 323 car.
      Instagram: Reichart12
      • ForcedFirebird
        • Feb 2007
        • 8300
        I've done that swap about 5 or 6 times, never had to use any other TOB than what came in the 325i kit.
        However, I have had issues when mixing and matching clutch kits. There are two thickness discs and 2 or 3 different shim spring configurations that if you mix up, the pedal will be low engagement. Some people like to use the HD Sach's PP which needs to have the matching disc. The HD plate has more springs putting the friction disc closer to the flywheel, so if you use the thicker clutch disc, you will have problems.
        Just last Sept we had a clutch fail at the 14hr of Sebring. Well, the driver managed to toast a second clutch and we were out of spares. We went to all the e30 racers and managed to get a couple clutch discs, and noticed the difference in thicknesses, we slapped the thicker disc in thinking it had "more meat left". The clutch was disengaging directly off the floor. Once we got it back to the shop after the race, we started comparing all the pressure plates and discs, and it became obvious why. The disc was thicker than the kits we have been using, it was so obvious at the point. For craps and giggles, I ordered a couple clutch kits from a few different mfgr's, and again, it was clear. Some discs were 9mm thick, some 7mm, and the thickness of the outer springs on the pressure plate corresponded to how thick the discs were.
        As long as you use a full clutch kit that was purchased all together as a kit, you should not have any issues.
        john@m20guru.com
        Links:
        • TobyB
          • 5293
          Hmmm, that explains a few things, John-
          for example, the Ireland puck disc is 7mm, which
          doesn't work with the standard Sachs PP.
          I too thought the eta bell was deeper-
          but I wasn't going to measure it until
          I had to use an eta trans...
          Different pressure plates (228-215-240, etc) DO
          have different height diaphragm fingers when installed...
          ...I've gotten in trouble with mixing things with trans/
          flywheel swaps...
          t
          • jeffnhiscars
            • Jun 2011
            • 6011
            Back to the OP, I installed a trans out of an e in to my cabrio. We used a stock i Sachs clutch kit w an RHD lightweight flywheel and it works fine. We also cut the wires off the e reference sensors and left them in the bell housing as plugs.
            Alice the Time Capsule
            • Whitten
              • May 2018
              • 3
              Cool thanks for all the help!
              • Reichart12
                • Aug 2012
                • 2165
                Good information. I guess I might not have needed to get the extra tob when I did this. Glad it still worked out.
                • ForcedFirebird
                  • Feb 2007
                  • 8300
                  They are just empty on the stock trans when they have the holes (mid face lift years).
                  Tomato, tomato. It works either way.
                  john@m20guru.com
                  Links:
