S2.93 with 3 Disk Not Locking
  • DTFE30
    • Feb 2011
    • 471
    Hey guys, looking for some advice here. I recently installed the Thayer motorsports 3 disk clutch setup in my S2.93. After the first ~25 miles of easy driving and wide turns the breakaway torque was measured at abt 60ft/lbs at the right rear. After a few weeks, I did a hard 2nd gear pull and snapped a cheap rear cv (car is S50 powered) and coasted to a stop. Fast forward to my next track event at Palmer motorsports park and the cars is almost coming to a stop on the hard uphill left hander because its spinning the inside wheel so bad. I re-measured the breakaway torque and I can barely get my wrench to click at 40ft/lbs. Is there a chance my new friction disks are spent? Maybe the Belleville washer isn't preloading it enough? Any other thoughts? I did contact Theyer and the got back to me quickly saying that is seemed to be acting normal. I find this hard to believe since I recently drove an e36 M3 on the same track and just drove right through that same turn with no spin at all. Thanks in advance for any feedback.
  • moatilliatta
    • 6150
    How bad did you drive it after the axle snapped?
    Have you drove the track before the diff was gone thru?
    @Zakspeed_US
    • Wanganstyle
      • 2828
      Garbage in garbage out.
      Using lower grade than Oem components with random guessing at clearances =...... not that great results.
      Buy a new aftermarket Lsd unit; or get parts from BMW/Porsche that are genuine zf and have someone who knows the units well build it all
      • DTFE30
        • Feb 2011
        • 471
        I only really drive it to and from the track. I didn’t get a chance to test it before the axle snapped.
        • DTFE30
          • Feb 2011
          • 471
          Are you saying the Thayer products are garbage? The install didn’t require any changes in clearances. You simply remove the spacer and put an extra friction disk and dog plate in.
          • Wanganstyle
            • 2828
            Cliff notes From original posters (your) thread
            1. Op installed set of parts that is supposed to be wonderful and work. Op didn’t measure anything
            2. Op drives magic muffin top product and it doesn’t work
            3. Op posts to complain and then argues that products installed and experience is not crap.
            4. Reality hits
            And yes; knock off products are garbage. Bmw doesn’t use crap and give shit for directions
            • DTFE30
              • Feb 2011
              • 471
              4. Reality hits
              Cliff notes:
              1. OP is troubleshooting and looking for ideas and knows that most likely the friction discs are damaged
              2. The parts came with a very detailed installation procedure that also matches multiple other DIYs found on this forum and others
              3. Wanganstyle must have done this 100's of times but clearly does not state what to measure and why the spacer plate (standard in all 188mm diffs) that was the only part removed in the process could cause a problem since Theyer clearly accounts for this when selling a standardized setup.
              4. The only other thing removed during installation of this kit is the output shafts and the end plates with the seals to remove the lsd unit from the housing. Each end plate has its own specific shim that was kept with its respective plate for re assembly. The LSD unit is a simple stackup of parts.
              5. Clearly Wanganstyle didn't read the post because I stated that the static breakaway torque was 60ft/lbs after I broke it in and after a broken axle and a few track days it was barely 40ft/lbs
              6. Wanganstyle has added deep insight to this thread about the internal workings and negative repercussions of DIY modifications to the BMW 188mm differential by stating, "use oem parts and pay an expert".
              • Wanganstyle
                • 2828
                Cliff notes:
                If you don't measure what came out and what went in then you are at the garbage in garbage out #1 infinite loop.
                BMW has an entire TIS dedicated to the e30 differential and LSD internal service.
                I suggest you read what the BMW factory published first before messing around asking the interweb for halp.
                • dsphil
                  • 495
                  I am no expert in lsd. Since you have the 3 disc setup and inner wheel slips during hard left turns, have you try hard right turn? My thought is that you have unequal limited slip with the 3 diac setup and cause one side to wear out faster than other side. Can you compare the breakaway torque on each side and report back.
                  327is
                  325es
                  325es
                  318is
                  Fiesta ST
                  E46 M3
                  • e30davie
                    • Apr 2016
                    • 1788
                    Do you have a link to this?
                    • Wanganstyle
                      • 2828
                      Spoonfeeding.com
                      • e30davie
                        • Apr 2016
                        • 1788
                        Lol, get off your high horse.
                        • Wanganstyle
                          • 2828
                          Get high and stop complaining.
                          There is no link; find the bmw technical document like any bmw tech would
                          • JGood
                            • Jan 2004
                            • 7959
                            Sections 11, 12, 13, and 14 will likely be relevant.
                            e30 restoration and V8 swap
                            24 Hours of Lemons e30 build
                            • e30davie
                              • Apr 2016
                              • 1788
                              Thankyou for posting it. Wasn't so hard was it:)
