light wieght fly wheel
  • 30vert
    • Jun 2007
    • 114
    who has the best light wieght fly wheel for the money?
  • dashboardmonkey
    FUCK YOUR WAFFLES
    • Jun 2008
    • 6158
    Search.
    This has been covered so many times
    -Andy
    • 30vert
      • Jun 2007
      • 114
      Originally posted by dashboardmonkey
      Search.
      i tried searching and could not find anything.
      • rThor432
        • Feb 2007
        • 3907
        Depends on the vehicle/engine, intended purpose of the vehicle/engine, and budget.
        For an M20 you can buy an 'i' flywheel for $50, spend $100 having it machined down from 17 lbs to 12 lbs, and spend $50 having it balanced. You have $200 in a light flywheel. But you have to do some research to find someone to do the work and you have to pull the flywheel from a junk car or wait for one to pop up for sale.
        You could also buy a light flywheel new for $300-700. Ready to bolt up with no extra time wasted at the machine shop.
        • bmwpower
          • 1556
          Where do you find one for $300?
          89 325is track project / 05 x5 / 99 M3
          E30 stuff for sale | Parts I'm looking for
          • rThor432
            • Feb 2007
            • 3907
            Honestly, I have no idea what was going through my head when I said $300 for a new flywheel...
            You can get a new light flywheel for $300 or less on Ebay though. Turner also sells flywheels for some engines for under $400. $300 was ridiculous to say though.. Sorry.
            • abit
              • Jul 2011
              • 423
              ok, won't make new tread, so I ask here.
              I have single mass flywheel, I want to make my engine a bit more responsive to gas pedal, plus maybe it will positively affect on engine ''power'' when accelerating, so I'm thinking about little shaving off my flywheel. (I think now I have 6,2? kilograms standart flywheel (from 1991 325i coupe))
              question is, how much I can shave off(what would be light but reasonable weight for flywheel), so the car/engine stays drive able on street(it won't throw me in front window when I lift off gas pedal etc :D), and it won't start to rattle gearbox at idle like b*tch :D
              engine is m20b28 with medium big cam.
              hope for some recommendations :)
              http://instagram.com/mundieriss
              my 88' m20b30 HERE!
              • abit
                • Jul 2011
                • 423
                anyone? :(
                my 88' m20b30 HERE!
                • digger
                  • Nov 2005
                  • 6216
                  12-13lb for stock fw, no guarantees on the rattle as some boxes do it worse than others
                  • varg
                    Florida Turbo Man
                    • May 2014
                    • 3439
                    Yep, you can get rattle even with a stock flywheel. Stock M20 flywheel in my car rattles when the AC is on and the idle drops. 4 cylinder though, a little rougher than an M20.
                    IG @turbovarg
                    '91 318is, M20 turbo
