CV Axle installation tool
  • fastair
    • May 2015
    • 34
    Sometime ago someone mentioned an inexpensive tool that could be used to pull the axle thru the splines on the rear hub. It seem like it was the same thing that is used on a Ford. Does anyone know what this is. My axle does not want to slide thru the hub.
  • tomstin
    • Mar 2015
    • 569
    Try here: https://www.rtsauto.com/re-installin...w-porsche-etc/
    "For cars that use M22 x 1.5 and M20 x 1.5 the following MUCH less expensive options are available.
    KD Tools 3532 (M22 x 1.5) also available on ebay as a no name “Ford Front Hub Installer #3532” for $16.95 shipped:
    2004 525i Manual - 1985 325E Coupe Manual
    • reelizmpro
      • 9552
      As someone who had to swap a few axles the last few years, I can attest to the usefulness of that "Ford" puller tool. It essentially pulls the axle through the hub by the threads vs the brute force method of pounding on the axle joint/boot on the opposite end. Like with many specialty tools, it makes the job much easier. Well worth the money, even if you only change 2 axles in your lifetime.
      88 M3 - LACHSSILBER
      89 M3 - ALPINEWEISS II
      • fastair
        • May 2015
        • 34
        Thanks, that is exactly what I was looking for.
        • eLKuRLy
          • Oct 2007
          • 360
          3020 or 3532??
          Ebay only has 3020
          • Vincenze
            • Apr 2019
            • 1031
            Pepboys rents the tool for $0. The information is in the link.
            • TobyB
              • 5280
              Awwww.... and I made one out of an old nut and some conduit- and a slide hummer!
              t
              diy and shave.
