M60 Swap thread
  • CorvallisBMW
    Long Schlong Longhammer
    • 13039
    #91
    Originally posted by OrganicMechanic
    I am researching to see if there is a taller 5th gear to swap in--love the close ratio but want an overdrive. The 5 speed is the same trans as the M3 e36 5 speed so there should be some options.
    Thank you! I've always wanted to be able to do this on the standard g260 or g265. I don't give a s**t about 5th gear acceleration, that's what 4th is for. I want highway MPGs :)
    • Jean
      • 18228
      #92
      I don't really care for mpg or highway cruising so I'll probably stick with the same diff I have now, 3.64 and go with a 5 speed since they are more common/cheaper/lighter etc :)
      • GaryE30
        • 4791
        #93
        Subscribed!
        Estoril E36 M3/4/5 | Toledo E53 X5 3.0 | LeMans E90 335D M-Sport
        • naika
          • 466
          #94
          3.64 isn't going to be too short of a ratio for the M60?
          I am going for a 2.93 with the M62
          A buddy of mine has an M30 swap with a 3.64 diff and that's just fine, but with the torque on the M60, I'd consider something a bit longer
          344is! Obd1 conversion
          • Jean
            • 18228
            #95
            I'll see how it works and go from there, like i said i don't care about mpg or cruising rpm. I may go with 3.25 again if 3.64 turns out too short for the events i attend.
            • Philo
              Ich esse kleine Kinder
              • 3334
              #96
              Why don't you just ask Courtney at MM. He'll know exactly what needs to happen for this. He's the driveline guy. I'll ask next time i'm down if you don't call before then.
              -tim
              Originally posted by Jordan
              I like the stance
              • Paukert11
                • Nov 2008
                • 1295
                #97
                sick i just picked up a one
                • Paukert11
                  • Nov 2008
                  • 1295
                  #98
                  I got it.!!
                  • Jean
                    • 18228
                    #99
                    Engine is out of the parts car...
                    I'll start a new thread covering the engine re-seal etc.. I noticed the back of the heads have round warranty seals/stamps... is this normal or is this an indication of a replacement heads?
                    Where is it? Oh there it is!
                    • Holland
                      • Nov 2008
                      • 7202
                      #100
                      And so it begins...
                      Originally posted by DEV0 E30
                      • e30guydownunder
                        • Jul 2008
                        • 874
                        #101
                        It will mean the heads have either been pulled and serviced by a shop / replaced with reco heads / new heads from a shop.
                        Basically when over heated the glue melts and the stamps move / fall off, warrenty void.
                        - Chris
                        Project M42 - 255 @ 19 psi
                        • Jean
                          • 18228
                          #102
                          Cool, just wanted to confirm, didn't think it was a factory thing...
                          • freeride53
                            • 11972
                            #103
                            Cannot believe that you're doing this!
                            You already have one of the nicest early models on our board, it will be even cooler to see another V8 E30 stateside..
                            Need to rename your car again ;)
                            1983 Peugeot 505 STI
                            1992 Volvo 240 Wagon
                            • White325is
                              • Oct 2006
                              • 5947
                              #104
                              This is going to br a great build as I hope to do the same thing..
                              • bmwmech1
                                • Jun 2010
                                • 1075
                                #105
                                So, how are those mounts? I have mine on the rotisserie now, getting ready to stitch weld all of the seams and start the cage... this is good reading, my friend...
                                Garey
