Slammin_e28's M60 swap. Annual update.
  • slammin.e28
    שמע ישראל
    • 12054
    #91
    YAY!!!!
    • senorcarey
      • Apr 2012
      • 80
      #92
      Where'd you order the mounts from? They look good.
      • slammin.e28
        שמע ישראל
        • 12054
        #93
        Garagistic. Mounts, spacers, hardware all for $188 shipped.
        Quality is great! Welds look very good! Very impressed!
        • JGood
          • Jan 2004
          • 7959
          #94
          They do look nice! Did they come with sleeves to center the spacers into the frame rails?
          e30 restoration and V8 swap
          24 Hours of Lemons e30 build
          • slammin.e28
            שמע ישראל
            • 12054
            #95
            Hmm.....just four bolts with washers.
            Are there not already sleeves in the frame rails of the car to center up the subframe?
            Edit: NVM, those are in the subrfame only. -_- I wonder if they'll pull out of my spare subframe.....
            • garagistic
              • Apr 2011
              • 1712
              #96
              Glad you liked the M60 swap motor mounts.
              Shameless plug:
              Garagistic is your trusted source for high-quality BMW performance parts, specializing in E30, E36, E46, and more. Discover custom-engineered components, from suspension upgrades to drivetrain solutions, designed to enhance your BMW's performance. Shop now for fast shipping, expert support, and unparalleled quality.
              What will your solution be for the RPM reading? We have an inline module to correct the RPM signal for v8s.
              • slammin.e28
                שמע ישראל
                • 12054
                #97
                Shameless plug:
                http://store.garagistic.com/ocart/bm...8%20rpm%20tach
                Tach I haven't looked at it yet, lol. I've got to put together a cluster from a couple I have laying around.
                With your converter, is the 4cyl coding plus still needed?
                • garagistic
                  • Apr 2011
                  • 1712
                  #98
                  Yes a 4 cyl coding plug will still be needed.
                  We look forward to seeing more pictures/progress of your swap!
                  • slammin.e28
                    שמע ישראל
                    • 12054
                    #99
                    Cool. Hopefully I can get some time to put the engine in and get the brake situation sorted out and the core support removable.
                    If I get time. I've got to fix the Rover so I can get my DD back.
                    • garagistic
                      • Apr 2011
                      • 1712
                      #100
                      Yes the brake situation is one of the hardest parts of the swap. We have a boosterless brake bracket if your solution ends up being more work then you would like. Uses wilwood/tilton brake pedals and puts master cylinders under dash. Only reservoirs stay in engine bay. Something to keep in mind. Let us know if we can be of any help or if you have questions. Good to see more m60 swaps happening.
                      • JGood
                        • Jan 2004
                        • 7959
                        #101
                        I'd definitely recommend using sleeves to center the spacer on the rails. I'm not sure if they are load bearing or just for ease of installation, but I know when Garey made my spacers, he also gave me a set of sleeves that he machined, and it made getting everything lined up much easier.
                        Also, I'd recommend the Dakota Digital SGI-8 for the tach signal. It's programmable, so you don't need to change your coding plug. You just tell it how many cylinders your tach thinks it's seeing (6) and how many it's actually seeing (8 ), and it does the rest. It takes 2 seconds to set up, just uses DIP switches.
                        $85 from Summit. http://www.summitracing.com/parts/dak-sgi-8/overview/
                        Not to take away from Garagistic's product, just an alternative. The more alternatives we have, the better!
                        • The Dark Side of Will
                          • Jun 2010
                          • 2796
                          #102
                          Correct alignment of the crossmember (and thus control arms and steering rack) pure and simple.
                          • slammin.e28
                            שמע ישראל
                            • 12054
                            #103
                            Core support out. Took about one hour.
                            Next step I gotta get it on the lift, drop the subframe, and slam the engine in.
                            • motomaster99
                              • Dec 2010
                              • 71
                              #104
                              Awesome man. :D I'm half way done with my m62 obd1 5spd swap. interested to see the hydro-boost in action...I went remote mount (e32/4).
                              Also heard there is another hydro booster that sits half in the car/half out so the MC can sit behind the strut tower and clears.
                              • slammin.e28
                                שמע ישראל
                                • 12054
                                #105
                                Oh hai guys! It's another month, so here's another update.
                                Rolled the car into the barn and onto the lift Saturday.
                                Cya'll next month!
