So you are saying 4.10 is not going to work eh? j/k
The semi-Comprehensive M60b40 into E30 swap Q&A
OEM v8 manual chip or dme - https://www.r3vlimited.com/board/sho....php?p=4938827 -
Lol... It'll *work* and make a quick car...
...that turns 3500 RPM at 60 and is RPM limited at 120 :p
I'm in touch with a guy who swapped out the stock 3.15 final in his E39 M5 for a 2.65. He said the S62 easily pulls the resulting 2.2 overall gear on the highway in a 4000 lbs E39.Comment
Heads are different (valves are different size) but the camshafts are the same.
source: www.bmwfans.info- E34 M5 (x 2) -
- E30 V8 Cabrio "Kylpyamme" -
- Alpina D10 Touring #33/94 -
- E46 318i Touring -
- Toyota Hiace 4wd -Comment
Yeah, we've also seen the weights posted but that raises questions. So, instead I just weight the things myself, and another member put the 5speed on the scales as well! Our scales might be +/- a few lb's, but at least another valid source.Mtech1 v8 build thread - https://www.r3vlimited.com/board/sho...d.php?t=413205
OEM v8 manual chip or dme - https://www.r3vlimited.com/board/sho....php?p=4938827Comment
Yap it's very good to get the weights verified!- E34 M5 (x 2) -
....does that mean that with with a choice between ltw jbr 240mm or 265mm flywheel (mounted to m60 e34), I HAVE to use the 265mm clutch kit to properly mate to the bigger input splines of the 6spd tranny? I think I understand this, but I think im still confused......
1. So that means that if I go with the smaller 240mm flywheel, I must still use the larger 265mm clutch disc. What happens to that extra 7.5mm "overhang" of the clutch disc on the flywheel on the edges???
2. If deciding to go 265mm all around to simulate a stock setup, then I see a problem with ride comfort by the lack of clutch springs in the stock e34 6spd clutch kit. Obviously, the dual mass setup accommodated for this originally, which is why it was not necessary to have springs in the clutch disc itself. Is this true?Recent Rebranding!!
E30 SM62/S62
E30 M60 V8
E30 M30 Big 6!
Instagram.com/garageaholic
Youtube.com/garageaholicComment
The hub springs or corresponding function performed by the dual mass flywheel is only to quiet gear rattle in the transmission. It has nothing to do with being easy to drive.Comment
So talking e34 6spd lightweight flywheel option only...
1. E34 size flywheel and clutch, which is 265mm friction disc and flywheel, either OEM or lightweight
2 E39 size flywheel and clutch, which is 240mm friction disc and flywheel, either OEM or lightweight
3. E31 850CSI flywheel and clutch, which is 280mm friction disc and flywheel,
JB racing complete setup.
Obviously, the larger friction surface setups are better, in the sense of the larger area of the disc, but the 240mm setup is used in the E39 540, M5 and Z8, so it's not a "bad" choice. I have an E31 whole setup I pulled from a customers car, for sale. The friction disc needs replaced and the PP and flywheel surfaces need re-surfaced, but I'm selling the whole setup for $500. It's the aluminum flywheel, PP, disc, slave and throwout bearing. New, it goes for $2500 for the whole setup, so it's a pretty good price. I can't use it on my 5 speed setup, or I'd keep it. If it doesn't sell, I'll put it in my E34 540 6 speed.
Hope that helps out your "confusion" a little. If you're interested in the setup I have, or have any more questions, just PM me...
Garey
The synchronizers create the torque that accelerates or slows the input and counter shafts so that the transmission can go into gear. The clutch disk is obviously splined to the input shaft. Because of its diameter, the disk accounts for the vast majority of the moment of inertia of the transmission. A larger diameter disk is more difficult to accelerate or slow down by a factor of the radius squared relative to a smaller disk. This means it takes the synchros longer to match shaft speeds in the transmission and shift times are increased.Comment
The larger diameter disk slows down shifting.
Garey
thanks for the explanation! but I thought you can't use the e39 clutch which is 240mm because the 6spd input splines don't match up, hence you are pigeon -held into HAVING to use the 265mm clutch kit from e34 6spd. if I can use the 240mm clutch kit, then I might opt to do that.Recent Rebranding!!
E30 SM62/S62
E30 M60 V8
E30 M30 Big 6!
That may be true in a very purist sense of crunching numbers, but we are talking about an increase of friction surface area vs. a 15mm increase in diameter. Some may feel that an imperceptible, nano-second slower shift is far less important than having the largest friction surface area available, especially in higher horsepower applications. This is debatable and subjective to the individual...;)
Garey
Guys who went from 9 1/8 to 9 11/16 clutches (similar diameters to the BMW 240mm) in Fieros, for example, notice significant increase in shift times.
My recommendation is always to use the smallest diameter disk that results in pedal load and chatter that is acceptable for the application, understanding that smaller disk diameter, higher clamp loads and more aggressive friction materials all go together...Comment
I actually just put clutches in an 01 540i 6 speed and an 06 650i 6 speed and although the transmissions/engines are different, the clutches are the same size, 240mm. They both use the same Self Adjusting Clutch setup, even though the motors are different and the transmissions are different. That's why there's been so much effort in finding alternative clutch/trans options for the earlier V8's... different models and even engines can yield the same clutch setups, so you have to be diligent in your research. The clutch I'll be using is not even originally offered as a V8 clutch, but the spline/diameter/stack height is correct for my application. Does it all make more sense now?
GareyLast edited by bmwmech1; 11-17-2011, 08:07 AM.
Hey man, I thought I'd jump in and clear up some of your confusion... THE main difference between the 2 transmissions, besides the extra gear is the input shaft diameter and number of splines. The 6 speed was used in the E34 and E39 so either flywheel will work for the 6 speed, you just need the proper 6 speed clutch kit diameter for the flywheel you are using. The 5 speed proper clutch kit, with the correct shaft diameter and spline count only comes in a 240mm diameter friction disc, which negates being able to use the E34 6 speed flywheel which uses a 265mm diameter friction disc. You can use an E34 5 speed flywheel from an M60B30 or an E39 540i flywheel from an M62B44, which both utilize the 240mm friction disc diameter. Clutch kit for the 5 speed should be sourced as a E36 328i or E39 528i clutch setup, in whatever stage of performance you choose. Plenty of options out there. As far as lightweight flywheels go, either size can be used for the 6 speed, only the 240mm diameter unit for the 5 speed. The E34, 265mm clutch/flywheel setup will only work for the 6 speed. Bruce has a pretty comprehensive breakdown on what fits and what doesn't, we'll see if he chimes in.
Hope this helps...
Garey
"Basically, there are three models of BMW that used this clutch kit - e36 328i (all body styles), E39 528i Sedan, and Z3 2.8 Roadster. The OEM clutch kit is part #21211223602, but again, we used the Clutchmasters upgrade for the application. Given the torque differences between the 2.8L six, and 4.0L V8, I would be very hesitant to use a stock clutch kit. We chose a lightweight flywheel, but it is dimensionally identical to a stock flywheel, so the stocker should work (just don't drop it on your foot)."
Flywheel is e39 540i. We used a JB Racing unit.
So now, when you do a search on "5-speed clutch", there will be yet another hit :-)
-BruceComment
Garey
